Exactly.
Everything works great, except loading the full home assistant page in any of the tor browsers for iOS.
Exactly.
Im here to bring HOPE to the IOS users.
Im using the product below, it loads the full hassio login page.
Right now i am still unable to make it work, im having an error āāUnable to connect to Home Assistantāā after i put my credentials.
Safe Browser Secure
Safe Browser Secure is a free IOS/IPhone/IPad browser that has a very stable TOR implementation to allow you to browse normal web sites anonymously and access .onion sites. It also supports TOR bridges, and is the only iOS TOR browser to support pluggable transports (obfs2, obfs3 and ScrambleSuit), crucial if your government or ISP blocks TOR, like the Great Firewall of China.
I found that on my hassio log:
Log Details (WARNING)
Mon Oct 29 2018 23:37:03 GMT-0300 (HorĆ”rio PadrĆ£o de BrasĆlia)
Login attempt or request with invalid authentication from 172.ip.ip.ip
The addon gives me an onion adress, but when trying to reach that the Tor browser says:
āDe verbinding werd geherinitialiseerd
De verbinding met de server werd geherinitialiseerd tijdens het laden van de pagina.ā
It used to work perfect, before I had to reinstall a snapshot.
Are there some cached files I first need to delete or so?
Maybe it is not possible to combine duckdns+letsencrypt with the tor addon?
Hi.
Is it possible to access HA using Tor when my ISP uses carrier grade NAT? Iāve searched but didnāt find a definite answer. Iāve only found one person who claimed it was possible, unfortunately without going in to details. When I try I canāt connect and it times out.
This is what I would like to know too - I just signed up for a 4G internet connection (internet is really bad here in some parts of Australia) and have ISP NAT and no public IP. I tried installing the addon just now and didnāt have any luckā¦
I think we are out of luck. If you eventually get it working, please let me know.
Great job Frenck ,it works flawlessly.
The add-on does work and allows access to HA instance over Tor network.
However, as previous users pointed out, the documentation needs to be changed, namely:
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
Hi, did you manage to access hole assistant with Firefox?.. browser for Android (alpha) works fine but forget loggins too
The only way that works for me from android mobile is Orfox. Tor browser doesnāt work.
Regarding Firefox, I tried only a desktop version and it doesnāt work if you configured your site as stealth, just because I couldnāt find where to enter that secret cookie info (see my post above)
I am in the same boat with 4g. Have you found any solution for remote access?
I hope Home Assistant cloud would help
As a matter of fact, I just got i working tonight
I tried Tor browser for Android and i works. I am still trying to make it work with āstealth modeā enabled. I had to change the ports to āYOUR_HA_INTERNAL_IP:8123:80ā.
EDIT: Changed āhidden serviceā to āstealth modeā
Contrary to AhmadK and Fernandex00 i have also āstealth modeā working. I am using Tor browser for Android (alpha). It remembers my auth cookies between sessions too.
Iām using Tor brownser for Android, it works, but every time I got to enter credentials, even if the page is reloaded
Just get the update today for Tor brownser alpha and I unable to enter home assistant, this happens after set the username and
Error: Message format incorrect: require key not provided @ data[āclient_idā]
perhaps itās a good idea to go to their github page and open a new issue?
I already did that here: https://github.com/home-assistant/home-assistant-polymer/issues/2828.
Please thumbs up the post if youāre experiencing the same issue.
It looks like the same problem.
Thor establishes a connection, but authorization in HA fails.
The same error in the TOR browser on Windows. And on android in orbot.
Youāre about to give access to your Home Assistant instance.
Logging in with Home Assistant Local.
Error: Message format incorrect: required key not provided @ data[āclient_idā]
config
ālog_levelā: āinfoā,
āsocksā: false,
āhidden_servicesā: true,
āstealthā: false,
āclient_namesā: [],
āportsā: [
ā8123ā
log home assistant
Log Details (ERROR)
Mon Feb 25 2019 02:05:25 GMT+0300 (RTZ 2 (Š·ŠøŠ¼Š°))
Data does not match schema: required key not provided @ data[āclient_idā]
