Same problem.
Same problem.
Yea same problem for me when I updated. Not an issue for now but definitely annoying
Yes same problem for me also. Seems to only affect sensors.yaml and binary_sensors.yaml ???
Yaml is already a pain ⊠if on top of that weâre getting wrong indications ⊠
Iâm using the VSCode a lot for my HA installation (Raspberry Pi 4, HomeAssistant OS) but one thing does not work, I canât preview images in my www folder, anyone can help?
Did you solve the âProperty platform is not allowedâ problem and if so - how?
For me it is the same ⊠within the included sensor yaml files â the same error message
Yes, by going back to version 4.0.0. Thereâs no official info about this âbugâ yet - why itâs happeningâŠ
It would be nice to hear some word from developersâŠ
You have it here
How do you do that? Thanks!
@pepe59: thanks! I hope that authors will find the problem soonâŠ
@oalbaf:Go to supervisor (if you have it) â backups and see if you have a partial backup of VS4.0.0. and restore VB code from that.
If you donât have supervisor then⊠well, if you have HA and addons in docker then you can remove current version and install earlier one, if i remember correct. But i canât tell you details doing that since i donât have docker so i donât know exact details.
Since sometime in the past few weeks, auto completion of HA entities and (mdi) icon name completion stopped working in my vscode addon (installed in a HA supervised installation).
TBH I have no idea what could have caused this change.
Is there anything I could check to find out, why this isnât working anymore?
I had a similar observation and digging in found that the most recent add-on update must have tipped the CPU requirement for me. When the HA extension tries to evaluate auto-completion names, the node process will max out the CPU in my VM for some time. If I wait long enough, auto completion will work, but itâs too slow in general. I added an extra CPU to the VM and that helped some, but not much.
Okay, I should clarify this a bit, as I suspect, this is not a performance problem in my case: The auto completion is generally working, i.e. popping up instantly w/o delay, but itâs missing any HA related suggestions:
Ever since VSC got renamed to Studio Code Server the window.autoDetectColorScheme setting is ignored for me and doesnât work. Running on Chrome under macos. Anyone else seeing this or is it just me?
Studio Code server 4.1.0 complains of platform: webostv.turn_on: Value is not accepted. Valid values: numeric state after migration to HA 2022.02 which introduced WebOS integration breaking changes.
Configuration is ok and works as expected:
Great Addon!
I have a question regarding configuration. Can I add to packages definition pip3 install command to install python modules on startup? I tried regular command to but it is not working but I can install modules in addonâs in terminal window after installing python3-distutils, python3-apt on startup.
Artur
Hello.
What kind of auto-completions does this plugin support? I rarely get any useful autocompletion, and I am wondering if it is limited to certain things and/or properties?
For example, should I get auto completion inside this template?
brightness_pct: "{{states('input_number.brightness') | float(0)}}"
That will be awesome, but I donât know if this is possible. Will love to know the limits, so I canât know what to count on and what to have at hand to copy-paste
Iâm facing the same problem since the upgrade.
Created an issue on Github, feel free to add your info.
Having âStudio Code Serverâ available is pretty amazing in HA running with the HA app on Mac. But some basic things donât work at all:
Iâm also not sure how to upgrade it from v4.0.x to v4.1 ⊠I have enabled the local terminal but how and where do I upload the new release files? Thanks.
I just inatalled HA a few weeks ago to test it out, so I am quite a noob.
Yesterday I installed the Visula studio Code Server plugin. I am trying to use this in the browser.
But whenever I start it, the first time it seems to fetch some entities I get the attached erormessages. I really donât know what to do with that. Entities are not shownâŠ
Can you help please?
I forgot: This is running on VirtualBox on a Mac using the latest haos image.
