I see that this add-on has not been updated since 2019.
I have encountered two serious problems:
When using both CPU and MEMORY, usage increases significantly. For example, if you modify the code for a long time, the CPU can reach 40% on my mini-PC used as an HA server, and memory usage can reach up to 60%. This usage does not decrease once you stop using the add-on, but remains high, and to bring it back to normal values, you have to stop the add-on and restart it without entering it again! I think this is an important bug to fix.
With the latest Home Assistant updates, writing many types of sensors has been deprecated and the syntax changed. However, since Visual Studio Code has not been updated for years, this returns errors that do not exist, and even the code suggested by Home Assistant itself to change the syntax of the various sensors within the add-on is reported as an error, creating great confusion for those who use it.
Given that the deprecation expires in June 2026, after which these sensors will stop working if the syntax is not changed, I am officially requesting an update to the add-on in line with this new Home Assistant update.
