Home Assistant Community Add-on: Visual Studio Code
Port 8443 is used internally and not usable from the outside. A black screen indicates a browser cache issue. Try Incognito, if that works, make sure you clear your browser cache.
Looks like it is browser related! Works in chrome not in Safari! Is this a known problem?
Yes, Safari is not working at the moment. This is an upstream issue.
:tada: Release v0.3.0
Full Changelog
This release adds Hass.io Ingress support to the add-on :tada:
Also on this release, a major upgrade on the code-server and vscode running inside this add-on.
Memory usage and general performance have been improved significantly!
Furthermore, ack has been added for easy and quick command line search through your configuration files, e.g., ack light.livingroom.
Changed
  • :fire: Removes password option from documentation
  • :fire: Removes now obsolete i_like_to_be_pwned option
  • :arrow_up: Upgrades hassio-cli to v2.2.0
  • :books:Updates installation steps in README (#14) (@riemers)
  • :sparkles: Adds ack
  • :books: Update README.md (#19) (@riemers)
  • :arrow_up: Upgrades base image to v3.1.0
  • :arrow_up: Upgrades wget to 1.19.4-1ubuntu2.2
  • :arrow_up: Upgrades code-server to 1.792-vsc1.33.1
  • :hammer: Improves S6 finish scripts
  • :sparkles: Adds Hassio Ingress support + General refactor
  • :books: Fixes some typos in the documentation (#20) (@tjorim)
  • :shirt: Fixes Markdownlint warnings
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
Amazing work, thank you!
Fixed in v0.3.0 of the add-on.
I can no longer connect via my reverse proxy subdomain. I canā€™t connect using localipaddress:1337
log
[15/Apr/2019:16:54:14 +1000] 403 -(10.90.11.5) GET / HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36)
2019/04/15 16:54:14 [error] 449#449: *50 access forbidden by rule, client: 10.90.11.5, server: a0d7b954-vscode, request: "GET /favicon.ico HTTP/1.1", host: "10.90.11.100:1337", referrer: "http://10.90.11.100:1337/"
[15/Apr/2019:16:54:14 +1000] 403 -(10.90.11.5) GET /favicon.ico HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.103 Safari/537.36)
I do have ingress working and the side panel though.
Hi, what should be the URL for iframe with this new ingress mode in v0.3.0? This is what I have now and it is not working because the VS Code is no longer available at old port.
panel_iframe:
  vscode:
    title: VS Code
    icon: mdi:visual-studio-code
    url: https://myhomeassistant:port
panel_custom:
  - name: hassio-main
    sidebar_title: Visual Studio Code
    sidebar_icon: mdi:visual-studio-code
    js_url: /api/hassio/app/entrypoint.js
    url_path: vscode
    embed_iframe: true
    require_admin: true
    config:
      ingress: a0d7b954_vscode
Ingress support has been added, which means the add-on works via the cloud connection as well, simply by clicking the ā€œOPEN WEB UIā€ button on the add-on page.
You can still enable the ā€œoldā€ direct access method, by setting a port in the network section of the add-on configuration panel.
Yes - thatā€™s the part that doesnā€™t work.
Ingress is working
http://ip-address:1337 gives the NGINX error 403 as per above log
Awesome work on this, it was so slow before that I almost gave it up, now itā€™s useable for me! I have quite the old nucā€¦
Thanks! Do you think this ā€œa0d7b954_vscodeā€ is going to stay the same?
Yes, that is the add-on slug and is not changeable.
I guess soā€¦ donā€™t see why it wouldnā€™t
I have also issues to start the vscode and web SSH und via my Duck DNS/Lets Encrypt ngnix configuration. I get only a dark grey screen, but the app is not loading. With the ā€œconfiguratorā€ Addon + ingress its working fine. The path looks also a little different.
SSH path: https://xxxxx.duckdns.org:1234/hassio/ingress/a0d7b954_ssh not working
Configurator path: https://xxxxx.duckdns.org:1234/hassio/ingress/core_configurator working
Local its working. ( http://192.168.2.25:8123/hassio/ingress/a0d7b954_ssh )
Via nabu casa cloud its working, too. ( https://xxxxxxxxxxxxxxxxxxxxx.ui.nabu.casa/hassio/ingress/a0d7b954_vscode)
Whats the problem??
Are you showing a dummp port number? canā€™t both be 1234
Its only a placeholder but the port is nevertheless the same. I thought that is manged via ingress?! Its my HA port for the proxy
I donā€™t specify a port at all for my proxy. Caddy sees the subdomain and then forwards to ipaddress:portā€¦ I never specify a port in the proxt url
So I can go to
 https://xxxxx.yyyyy.duckdns.org/hassio/ingress/a0d7b954_ssh
