I forwarded port 443 for the proxy to a different port (1234), because 443 is alreay in for an other application.
But I think it should work like this
I ran the debugger and the error I am seeing is with the websocket connection.
NGINX Config:
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
server {
server_name homeassistant.example.net;
listen 80;
location /.well-known/acme-challenge/ {
root /var/www/certbot;
location / {
return 301 https://$host$request_uri;
server {
ssl_certificate /etc/letsencrypt/live/homeassistant.example.net/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/homeassistant.example.net/privkey.pem;
include /etc/letsencrypt/options-ssl-nginx.conf;
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
listen 443;
add_header Strict-Transport-Security "max-age=31536000; includeSubdomains";
ssl_session_cache shared:SSL:10m;
proxy_buffering off;
location / {
proxy_pass http://10.0.0.94:8123;
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
location /api/websocket {
proxy_pass http://10.0.0.94:8123/api/websocket;
Same for me
Release v0.4.0
Again a packed release!
code-server
has been upgraded to the latest greatest, shipping vscode 1.33.1 as well.
Service workers are added and a bunch of more optimizations, which should drastically reduce the initial loading times of the web interface.
@timmo001 added an option to disable sending anonymous telemetry data to code-server and @hjanum added a small change that makes AppDaemonās dash
files being picked up as YAML as well.
@riemers came by and added support for RedHatās YAML extension, which validates you YAML files while typing them.
The default user settings are tweaked for more logical and better user experience for working on Home Assistantās configuration files and support for Home Assistantās special YAML tags has been added. If you havenāt modified the default vscode configuration, the add-on will automatically upgrade these settings for you.
Finally, all command history from the built-in terminal will now persist across add-on restarts and system reboots. Which helps to find that command you used beforeā¦
Enjoy the release!
Changed
- Update code server to 1.868-vsc1.33.1 (#27) (@timmo001)
- Adds disable telemetry flag (#27) (@timmo001)
- Adds disable telemetry as an option (#27) (@timmo001
- Adds vscode YAML extension (#26) (@riemers)
- Adds *.dash extension for YAML (#24) (@hjanum)
- Adds user configuration upgrade method
- Updates README about section to match latest changes
- Persist userās ZSH history across restarts
- Tweaked default user settings for a better starting experience
- Fixes JSON lint issue
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
update VScode v4, now my panel_ iframe doesnāt work. What do I need to add to the config of panel_iframe. Iām work with Home Assistant 0.91.4. Thanks
vscode:
title: Visual Studio Code
icon: mdi:visual-studio-code
url: http://192.168.1.120:1337/
make sure you add port 1337 in the network section and it will work
Thank you David, that worked
As @DavidFW1960 said, if you re-assign a port to it, the iframe will continue to work the old way.
However it stopped working because this addon now supports ingress. If you wait until 0.92, there will be a simple checkbox to add an ingres addon to the sidebar. If you do not want to wait, below is a code section to add the addon to the sidebar using ingress.
Ingress works without exposing extra ports to the outside, so using it thereās no need to enable port 1337 again, and no need to forward that port on your router for remote usage.
panel_custom:
- name: hassio-main
sidebar_title: Visual Studio Code
sidebar_icon: mdi:visual-studio-code
js_url: /api/hassio/app/entrypoint.js
url_path: vscode
embed_iframe: true
require_admin: true
config:
ingress: a0d7b954_vscode
Also note, all of this information was already available in change logs, upgrade notes, and version notes.
Can someone point me to the settings file?
I made a change and would very much like to restore to default settings. (I made it unusableā¦)
I tried reinstalling end removing the container. But that didnāt help
Click on the default button at the bottom of the settings, also at bottom of network. Restart addon
Thanks for the tip, but sorry canāt even find that button.
Somehow I believe I clicked āshow in finderā when focussed on my zwave.xml file:
Now I canāt get rid of it anymore.
Ah, you meant those. No luck Iām afraid. These are the settings for the add-on itself. Iām looking for the settings inside the add-on that will help me get rid of the problem. Re-install and removing docker container/image donāt help.
There must be a config stored on the NUC somewhere.
Well I donāt understand what you canāt do because that screenshot looks fine to me
Sovled it, Clearing browser cache did the trickā¦
Release v0.4.1
This is a maintenance release that upgrades code-server and addresses an issue with open dialogs.
Changed
- Updates code-server to 1.903-vsc1.33.1 (#29) (@timmo001)
Release v0.4.2
This release adds support for the āAdd to sidebarā feature that became available in Home Assistant 0.92.
Please note: You need to have Home Assistant 0.92 or newer to be able to install this update.
Changed
- Updates Home Assistant requirement to 0.92.0b2
- Adds support for showing in sidebar
Hello!
I am running version 0.92.0 of hass.io on a Raspbian Stretch. I am able to install official addons as well as communitiy addons, but only Visual Studio Code is greyed-out and I cannot install it (see screenshot below). It says āThis add-on is not available on your system.ā
Iāve also tried this with the official hass.io āRaspberry Pi 3 Model B and B+ 32bitā image - same problem.
Any ideas?
VS Code add-on runs on x64 systems only
