Since the new app, Iāve been having an odd issue. My phone, which is on the same network as HA, is unable to connect. The error I get is ERR_CONNECTION_REFUSED. What am I doing wrong?
Hi, is there any option in the android app to have it installed but not controlled by the owner. I have 2 tablets for my children and I want to automate (send voice reminders) some rules. I want to use the apps voice tts for it thus it has to be installed. But since RBAC is not there and custom header was killed I want to restrict any access to the interface of the app. How can I do that?
I didnāt know that. I have just seen the setting.
But now I just tested it and itās a bit odd.
When I enable the lock I have to put my finger on the reader.
But when I toggle the password off I donāt have to put my finger on the reader.
Generally I would say that enabling a password is less of a threat than disabling it. So shouldnāt the verification be the other way around, or both?
How difficult would it be to get this app into the Amazon App Store for installation on Kindle / Fire devices (Without Having to side load the Google store bits)?
The full version of the app requires google play services, the minimal version does not so you can install that and use it. As far as the Amazon store there are no current plans to add it there.
There is not, you will have to try a custom card approach to this. I believe there is one where you can lock the card based on the user but not sure its all custom stuff.
You have to think of the app as a webview to the frontend because that is exactly what we are, you would need to get the frontend to support something like this for it to work in the app.
What about just using a launcher where you can hide apps from the launcher? Depends on how old and how desperate to control the smart home your kids are, this could work.
You could still open the app by search OR by Opening it from the play store.
Iāve just been setting up an additional unifi camera on HA 0.117.6 (Python 3.8 venv, via Nabu Casa).
I display these cameras using a picture entity card with a live view when selected - this usually requires me to enable āPreload streamā per card after a configuration change which it did today.
In the past this has never been an issue to enable in the mobile app, however running v3.0.2-full on a Pixel 5 I am unable to check the option when displayed in the app.
I should note that this is not the case in Chrome on the same phone using the externally accessible Nabu Casa address and it wasnāt an issue when setting this phone up with the HA app in October.
Iāve also tested with and without the āAutomatically Close Connectionsā user configuration option on and off, which makes no apparent difference - it feels rather like the touch is not recognised within the app.
Have I missed something in the release notes that would explain this?
