Home Assistant Companion Apps: New and Upcoming Features
Is it normal that after disabling some sensors on the app and after restarting HA, the disabled sensors are still present in developers/states? Do i need to force close the app and then run again to make these changes reflected also in the HA frontend?
Sensors are not removed when disabled from the app
So, if i am using some of them inside lovelace, i must delete them one by one from entities?
Clearly they are not anymore refreshed if disabled from the app… Is it so?
disabled sensors do not send any data back home, you will need to remove/disable them to stop seeing them.
