It would be nice if possible to create images following the android guidelines for creating Action bar, Dialog & Tab icons used in notifications.
For example, Action Bar Icons require a file size of 32×32 pixels at the baseline size (MDPI). However, the image itself must be no more than 24×24 pixels centred within the Icon file. Is that possible with the camera proxy?
24 × 24 area in 32 × 32 (mdpi)
36 × 36 area in 48 × 48 (hdpi)
48 × 48 area in 64 × 64 (xhdpi)
72 × 72 area in 96 × 96 (xxhdpi)
96 × 96 area in 128 × 128 (xxxhdpi)*
Notification icons
22 × 22 area in 24 × 24 (mdpi)
33 × 33 area in 36 × 36 (hdpi)
44 × 44 area in 48 × 48 (xhdpi)
66 × 66 area in 72 × 72 (xxhdpi)
88 × 88 area in 96 × 96 (xxxhdpi)*
Thank you for your link to the camera proxy. I solved the problem, the images needs to have sizes that can maintain aspect ratio when scaled.
640x480 (VGA, default) 640*480, ratio 10x7,5 is not working without crop due to android notification scaling problem, the notification image is not shown. Correct ratio has to be created with camera proxy using the camera proxy crop function in some way?
1024x768 (XGA)1024 x768, ratio 16x12 - OK No scaling problem. Notification image is scaled properly without crop, (can devide with 64 to get ratio).
Could you share the camera proxy configuration you have? Maybe that can be something we add to the companion docs to help people out that are looking for similar results
When I place a new widget they are there. I was talking about existing widgets, those icons are (all) gone. Taking a screenshot will not add more information.
Guess that will not happen. It’s quite clear - if you look at github - that there is mainly only one user responsable for this blockings, lockings and so on.
Sad thing no one will say anything against it even if it violates the code of conduct
Hi, is anybody else having problems with push notifications on ios since the app has been updated. since the app update non of the notification come trough. Node red shows that the notification has been sent, i have checked all the phone settings and also renewed the Push ID.
Check to see if you have a duplicate mobile app integration. I didn’t heed the warning to remove the original integration first, and just logged in again, and found that my device was indeed duplicated. And Node-RED was trying to send the notification to the old integration. To fix it, I removed both, reset the app and logged in again.
I have an older unused Android v4.2.2 tablet.
Is there a version of this app that works with this version?
If possible, I would like to use it as an extra wall mounted system and since it’s a only 7" it would be nice if this could be in kiosk mode with the app.
I don’t think this is possible with a browser so therefor this path.
