I had the same experience as @pergola.fabio and i’m using a OnePlus 7, so maybe it’s OnePlus related, i don’t know.
But i tried the TTL / prio solution at it works for me
So thank you for pointing at a possible solution
actions:
- action: close_garage
title: Close Garage Door
priority: high
ttl: 0
message: Message to display
title: Message Title
still not working for me either, tested below script, maybe its the image? but what i noticed, the message didnt come, i had to wake up phone, and even i had to open the “home assistant” app , the the push message arrived
aa_test:
alias: Doorbell notification
sequence:
- service: !secret notify_ha_fabio
title: "Alert"
message: "Someone at the door"
# actions:
# - action: "close_garage" # The key you are sending for the event
# title: "Close Garage Door" # The button title
image: "https://i.pinimg.com/originals/0f/7b/fa/0f7bfa4e6775b5977694a6036fc85b48.png"
priority: high
ttl: 0
one feature i miss for notifications is to be able to select a sound
based on script/message i want to have another notification sound
is that already possible and not documented? to use somekind of internal sound name?
Since the 1.6 release i get a huge delay for the notifications… What i was getting at the set hour now i get the notification with a 6-7 minutes delay… Is someone else having the same issue?
I have followed the example for the formatting of the actionable notifications, which at first seemed to be working find, but i’ve noticed that multiple actions are being triggered when clicking on the notification button, even though i’m only expecting one to run
did you make sure to change the action keywords? I just tested this myself with 2 actions and both actions were sent separately when i selected them. both automations below did not run at the same time but only when each action was selected
My sensors for battery level and wifi name are working but I thought they would have been prefixed with the device name as set in the app. I’m planning to get my wife to install this app as well, and I don’t want ambiguity of “battery_level” vs. “battery_level_2” depending on which phone connects first.
Any entity coming from the app should be prefixed with the device name. At least the device tracker entity is named after the model of my phone, but even that should use the device name.
I submitted a fix for this exact issue that will be in 0.106 but it wont impact existing installs only new ones.
Also you can rename the entities that are created by the mobile app as they are registered entities. Once your entity is registered, changing the device name in the app will not override it. There is a feature request to set the device name during onboarding that will correct this going foward. In the meantime you can set the device name in Settings > About Phone and next time you install the app it should use that name.
The notify service call will be updated when you update the device name in App Configuration and then perform a HA restart.
For the device tracker the device name needs to be set before the entity is registered. So if you set it in Settings > About phone then next time you start fresh with the app it will pick up the name you set.
I have family members that aren’t thrilled with being tracked all the time. Would anyone else be interested in an “only track and share home/away" option in the app? That would satisfy their desire not to be tracked all the time and allow me to finish a number of automation which I currently cannot because of their qualms.
