Will this also work on the plain Amazfit Bip5, not the just the Unity? They seem similar missing the GPS. EDIT: I can confirm it does, but no idea how to get any data from the watch back into HA.
In the coming weeks you ll have all the info!
Old whatches could run Mini Program, docs is here
Could somebody help doing that?
Amazfit GTR 2 Amazfit GTR 2e Zepp E (Round) Zepp E (Square) Amazfit T-Rex Pro Amazfit Pop Amazfit GTS 2 mini
These whatches probably run mini-programs
Nope, not working. Tried the “bat” and the manual methode but lots of errors…
C:\Users\ed>npm i @zeppos/zeus-cli -g
npm warn deprecated @npmcli/[email protected]: This functionality has been moved to @npmcli/fs
npm warn deprecated [email protected]: This functionality has been moved to @npmcli/fs
npm warn deprecated [email protected]: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
npm warn deprecated [email protected]: Package no longer supported. Contact Support at npm | Support for more info.
npm warn deprecated [email protected]: This package is no longer supported.
npm warn deprecated [email protected]: Rimraf versions prior to v4 are no longer supported
npm warn deprecated [email protected]: Glob versions prior to v9 are no longer supported
npm warn deprecated [email protected]: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
changed 557 packages in 42s
91 packages are looking for funding
C:\Users\ed>zeus -v
node: v22.12.0
npm: v10.9.0
zeus: v1.6.2
zpm: v3.1.1
C:\Users\ed>git clone https://github.com/TitoTB/ha-zepp
Cloning into ‘ha-zepp’…
remote: Repository not found.
fatal: repository ‘https://github.com/TitoTB/ha-zepp/’ not found
Sorry about that. We are about to launch new and improved version, that you can download from the zepp store.
Stay tunned!
Question: Does this make sensors available on HA which shows stuff like steps, distance, etc?
