Home Assistant Companion macOS app's window size
I like the macOS app very much.
However, I miss that the app remembers the window size when I changed it.
Would it be possible to make it so that the window size is remembered when the app is opened again?
Kind regards,
Roel
Hi, did you find a solution to this? Thanks
Also looking forward to some kind of a fix for this.
Been a long time since I asked this and have never gotten an answer. So it is still not fixed :-(.
I do not think it is possible. Looking under ~/Library/Preferences/ I do not see a settings file (.plist) for Home Assistant. Sounds like the developers are not leveraging that option.
The app’s behavior for window placement is based on a global system preference because it is a Catalyst app. See:
The app is sandboxed and its preferences are in a container, see: ~/Library/Containers/Home Assistant/Data/Library/Preferences and ~/Library/Group Containers/group.io.robbie.homeassistant/Library/Preferences.
