Howdy All! Any good ZWAVE or ZigBee or even WIFI Alarm control panels that will work in HA?
I want to be able to allow my kids to disable the alarm system from a panel instead of setting them up as usuers in HA.
Do you really want an Alarm control panel or just a keypad like this one connected to a sensor of your choice? My alarm keypad requires a control panel which is probably not what you want.
My goal is to just allow the kiddos to be able to arm and disarm. currnetly i just moved into a house and haave not setup my alarm system yet. the pissed off part is that the builder did not wire the house for an alarm system. so I am weighing the solutions currnetly as to either use a HA alarm setup using gocontrol sensors and motion detectors, but the key pad is just to disarm and arm for the kids. I wish i had the panel function that had everything already supplied with it and works with HA.
I was looking at this:
https://www.google.com/aclk?sa=L&ai=DChcSEwjz4IGZ_LjVAhUCBGkKHQIHDbYYABAHGgJpcQ&sig=AOD64_3j24AzgiA1zVWbREKws5GMuKd26A&ctype=5&q=&ved=0ahUKEwiLwvqY_LjVAhXqz4MKHfxvCzsQvhcINA&adurl=
but i have seen no working integration with HA on the product. I know its going to probably be some zwave alarm setup in the long run.
@RobDYI how did you set this up in HA, If you don’t mind me asking sir?
I didn’t use that keypad but instead use a DSC alarm system with its DSC keypads but connected to HA through envisalink.
The keypad above can be connect to HA through a pi I believe. They have a relay (switch) on the back of the keypad that you can connect the ground and a gpio pin to on your pi. you can then use HA to create a sensor to monitor that gpio pin and use it as a lock sensor in HA.
