Hi i am new to the home assistant area and am stuck, i am unable to find my configuration.yaml file with 3rd party software and can only edit it through putty. i am getting these errors.How would i fix this, thanks for the reply’s?
2017-06-12 03:27:34 WARNING (MainThread) [homeassistant.config] Incomplete core config. Auto detected latitude: -26.2309, longitude: 28.0583, name: Johannesburg, time_zone: Africa/Johannesburg, elevation: 1693
2017-06-12 03:27:37 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=44 from 2017-06-09 19:01:53.744359)
2017-06-12 03:27:37 ERROR (MainThread) [homeassistant.loader] Unable to find component .homeassistant
2017-06-12 03:27:37 ERROR (MainThread) [homeassistant.setup] Setup failed for .homeassistant: Component not found.
2017-06-12 03:28:00 WARNING (Thread-3) [netdisco.ssdp] Error fetching description at http://0.0.0.0:5431/dyndev/uuid:e8377af0-2ee0-e02e-f07a-37e837f0e000
2017-06-12 03:48:58 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal read error on socket transport
File “/usr/lib/python3.4/asyncio/selector_events.py”, line 582, in _read_ready
data = self._sock.recv(self.max_size)
OSError: [Errno 113] No route to host
2017-06-12 03:49:01 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal read error on socket transport
2017-06-12 04:27:43 ERROR (MainThread) [homeassistant.components.updater] Could not contact Home Assistant Update to check for updates
2017-06-12 05:50:59 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal read error on socket transport
