Very NEW at Home Assistant and how it works. I have been reading posts and documentation, but I am stuck on this one.
Hardware
- HA is installed on a Raspberry Pi4 Mod B (4Gb) (with assigned Static IP)
- Wired to network
- NodeMCUv2 - ESP8266v2 (with assigned Static IP)
I am using the Pi’s USB port to configure the NodeMCU. I configured the NodeMCU with no problems after a few dumb starts. While connected to the Pi’s USB port the NodeMCU and DS18B20 were found and ESPHome started logging the temperatures. I looked at my router and verified the Static IP address that was assigned to the NodeMCU was active. I tried to ping the NodeMCU’s IP address, but it is unreachable. Home Assistant’s IP address was active and responded to the Ping. Did I miss something to install in HA? In the NodeMCU configuration? The yaml is located at the bottom of this post.
Thank you in advance for any assistance
Here is the install process:
INFO Reading configuration /config/esphome/temperatures-4.yaml...
INFO Configuration is valid!
esphome:
platform: ESP8266
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "47787fec......8695dad"
wifi:
ssid: "IoT"
password: "lkglkj....293475aj"
manual_ip:
static_ip: 192.168.40.21
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "Temperatures-4 Hotspot"
password: "WXg....4W88"
captive_portal:
dallas:
pin: D4
# Individual sensors
- platform: dallas
address: 0x2302049245F1DE28
name: "Office Temperature"
