Hello everyone,
Since I want to set up an “thread border router” with the help of HomeAssistant, I bought the Connect ZBT-1 and tried to connect it according to the instructions. (Home Assistant Connect ZBT-1)
Unfortunately, my HomeAssistant Green does not seem to recognise it automatically. (like in step 2 of the guide)
However, I found it in the full hardware list.
So I searched the forum here and found the following:
I have run the SHH script and my ZBT-1 Connect is now also displayed as follows:
ttyUSB0
/dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_54d28d500339ef11923ae0d154516304-if00-port0
However, the problem persists that my Home Assistant does not find the stick automatically and I therefore cannot configure it for Thread under System > Hardware.
Does anyone else have an idea what this could be due to or is there a manual way to flash the stick and use it as an open thread border router?
(I don’t want to use multiprotocol or Zigbee with the stick, I have another sonoff stick for this)
Greeting and thanks for your help
Zmash
Edit:
Full Device entry:
Attributes:
DEVLINKS: >-
/dev/serial/by-path/platform-fd800000.usb-usb-0:1.1:1.0-port0
/dev/serial/by-path/platform-fd800000.usb-usbv2-0:1.1:1.0-port0
DEVNAME: /dev/ttyUSB0
DEVPATH: /devices/platform/fd800000.usb/usb4/4-1/4-1.1/4-1.1:1.0/ttyUSB0/tty/ttyUSB0
ID_BUS: usb
ID_MODEL: SkyConnect_v1.0
ID_MODEL_ENC: SkyConnect\x20v1.0
ID_MODEL_ID: ea60
ID_PATH: platform-fd800000.usb-usb-0:1.1:1.0
ID_PATH_TAG: platform-fd800000_usb-usb-0_1_1_1_0
ID_PATH_WITH_USB_REVISION: platform-fd800000.usb-usbv2-0:1.1:1.0
ID_REVISION: '0100'
ID_SERIAL: Nabu_Casa_SkyConnect_v1.0_54d28d500339ef11923ae0d154516304
ID_SERIAL_SHORT: 54d28d500339ef11923ae0d154516304
ID_TYPE: generic
ID_USB_DRIVER: cp210x
ID_USB_INTERFACES: ':ff0000:'
ID_USB_INTERFACE_NUM: '00'
ID_USB_MODEL: SkyConnect_v1.0
ID_USB_MODEL_ENC: SkyConnect\x20v1.0
ID_USB_MODEL_ID: ea60
ID_USB_REVISION: '0100'
ID_USB_SERIAL: Nabu_Casa_SkyConnect_v1.0_54d28d500339ef11923ae0d154516304
ID_USB_SERIAL_SHORT: 54d28d500339ef11923ae0d154516304
ID_USB_TYPE: generic
ID_USB_VENDOR: Nabu_Casa
ID_USB_VENDOR_ENC: Nabu\x20Casa
ID_USB_VENDOR_ID: 10c4
ID_VENDOR: Nabu_Casa
ID_VENDOR_ENC: Nabu\x20Casa
ID_VENDOR_ID: 10c4
MAJOR: '188'
MINOR: '0'
SUBSYSTEM: tty
TAGS: ':systemd:'
USEC_INITIALIZED: '3525584449903'
My System:
Home Assistant Green
Core 2024.11.3
Supervisor 2024.11.4
Operating System 13.2
Frontend 20241106.2
