Looks like you can add comments to posts by enclosing them in angle brackets - have I got this right?
Used sparingly this might be useful in the index post - to indicate where a link appears in more than one section, for example. (I’ve added a couple of comments in the Troubleshooting section.)
They only seem to be visible in the edit box - not in edit history.
Now that I see your new addition I’m thinking we need something for using the context of a trigger too. Many people want to know which user did something, or whether a physical switch was flipped.
It is kind of documented, and perhaps here we can argue too that the docs should just be improved.
Anyway, there are numerous posts about this, but here are two of interest:
Context will be difficult because all the information that’s widely used about it is simply wrong. People are using a blanket copy/paste template to get a specific scenario and that’s it. Context is extremely powerful, but there’s plenty of gotcha’s related to it.
E.g.
If you get the context in an automation between the trigger and actions, it’s 100% wrong unless you get it from the trigger.
If you get the context in the action section, it’s correct.
Context is populated after conditions and before actions run.
Indeed! There are many, many posts on contexts. These are just two of my own reference ones that I’ve saved.
Petro’s articulated the problem:
I’m not sure yet how to distill this into useful, concrete information.
I’ve never been able to get very reliable code working using contexts, except for the simplest of cases, because one needs to infer things. You have to basically generate the different scenarios for your own case and it gets quite tricky if you have e.g. a script called from an automation and in the script you access the script’s context.
Perhaps the real issue is that some of this should rather be baked in at at a deeper level or even provided by integrations themselves.
I’ve been mulling one for triggers, trigger variables, limited templates in my head since this started, but it always turns into a bible . too long. Working on breaking that up.
Would anyone like to do a piece on importing files into HA for local access? How to import them; where to store them; how to reference them in dashboards and media players etc.
I imagine it would mention File Editor and Samba Share, both of which are “official” add-ons.
I have some ideas, but not the complete picture on the importing stuff. I use Samba but don’t have a complete story. I’d be glad to colab on it if someone wants to start one in a private group chat.
