Home Assistant Core can't start
Decided to update Home Assitant Core, OS and Supervisor to the latest versions. I successfully did so with both OS and Supervisor but before I got to the Core it wasn’t possible since it crashed.
Core Info
arch: aarch64
audio_input: None
audio_output: None
boot: true
image: ghcr.io/home-assistant/raspberrypi4-64-homeassistant
ip_address: 172.30.32.1
machine: raspberrypi4-64
port: 8123
ssl: false
update_available: true
version: 2022.6.7
version_latest: 2022.7.3
watchdog: true
Core Logs
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
2022-07-13 14:03:22 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=logger, service=set_default_level>
2022-07-13 14:03:22 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=logger, service=set_level>
2022-07-13 14:03:22 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=system_log>
2022-07-13 14:03:22 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logger>
2022-07-13 14:03:23 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder>
[13:03:23] INFO: Home Assistant Core finish process exit code 1
[13:03:23] INFO: Home Assistant Core service shutdown
s6-rc: info: service legacy-services: stopping
[13:03:23] INFO: Home Assistant Core finish process exit code 256
[13:03:23] INFO: Home Assistant Core finish process received signal 15
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
2022-07-13 14:08:55 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=logger, service=set_default_level>
2022-07-13 14:08:55 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=logger, service=set_level>
2022-07-13 14:08:55 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=system_log, service=clear>
2022-07-13 14:08:55 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=system_log, service=write>
2022-07-13 14:08:55 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logger>
2022-07-13 14:08:55 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=system_log>
2022-07-13 14:08:55 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder>
[13:08:56] INFO: Home Assistant Core finish process exit code 1
[13:08:56] INFO: Home Assistant Core service shutdown
[13:08:56] INFO: Home Assistant Core finish process exit code 256
[13:08:56] INFO: Home Assistant Core finish process received signal 15
Supervisor Info
addons:
- icon: true
  repository: core
  slug: core_configurator
  state: started
  update_available: false
  version: 5.3.3
  version_latest: 5.3.3
- icon: true
  repository: core
  slug: core_samba
  state: started
  version: 9.5.1
  version_latest: 10.0.0
- icon: true
  name: Terminal & SSH
  repository: core
  slug: core_ssh
  state: started
  version: 9.3.0
  version_latest: 9.6.0
- icon: true
  repository: a0d7b954
  slug: a0d7b954_nodered
  state: started
  version: 11.1.1
  version_latest: 12.0.2
addons_repositories:
- name: Local add-ons
  slug: local
- name: ESPHome
  slug: 5c53de3b
- name: Expaso Home Assistant Add-Ons
  slug: 77b2833f
- name: Home Assistant Google Drive Backup Repository
  slug: cebe7a76
- name: Official add-ons
  slug: core
- name: Home Assistant Community Add-ons
  slug: a0d7b954
arch: aarch64
channel: stable
debug: false
debug_block: false
diagnostics: false
healthy: true
ip_address: 172.30.32.2
logging: info
supported: true
timezone: Europe/Lisbon
version: 2022.07.0
version_latest: 2022.07.0
wait_boot: 5
Supervisor Logs
22-07-13 14:02:47 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-ssh with version 9.3.0
22-07-13 14:02:47 INFO (MainThread) [supervisor.backups.manager] Found 5 backup files
22-07-13 14:02:47 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-07-13 14:02:47 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-07-13 14:02:47 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-07-13 14:02:47 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-07-13 14:02:47 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-07-13 14:02:47 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-07-13 14:02:47 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
22-07-13 14:02:47 INFO (MainThread) [__main__] Running Supervisor
22-07-13 14:02:48 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
22-07-13 14:02:48 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-07-13 14:02:48 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
22-07-13 14:02:48 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 2 add-ons
22-07-13 14:02:48 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
22-07-13 14:02:48 WARNING (SyncWorker_3) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
22-07-13 14:02:49 INFO (SyncWorker_3) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-samba with version 9.5.1
22-07-13 14:02:50 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-ssh with version 9.3.0
22-07-13 14:02:50 INFO (MainThread) [supervisor.api.middleware.security] /network/interface/default/info access from core_samba
22-07-13 14:02:55 INFO (MainThread) [supervisor.core] Start Home Assistant Core
22-07-13 14:02:55 INFO (SyncWorker_3) [supervisor.docker.interface] Starting homeassistant
22-07-13 14:02:56 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-07-13 14:03:10 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from core_ssh
22-07-13 14:03:10 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from core_ssh
22-07-13 14:03:10 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from core_ssh
22-07-13 14:03:14 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from core_ssh
22-07-13 14:03:16 ERROR (MainThread) [supervisor.homeassistant.core] Home Assistant has crashed!
22-07-13 14:03:16 ERROR (MainThread) [supervisor.core] Can't start Home Assistant Core - rebuiling
22-07-13 14:03:16 INFO (SyncWorker_3) [supervisor.docker.interface] Cleaning homeassistant application
22-07-13 14:03:16 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
22-07-13 14:03:16 INFO (SyncWorker_2) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version 2022.6.7
22-07-13 14:03:16 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-07-13 14:03:17 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from core_ssh
22-07-13 14:03:18 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from core_ssh
22-07-13 14:03:20 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from core_ssh
22-07-13 14:03:21 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from core_ssh
22-07-13 14:03:24 INFO (MainThread) [supervisor.api.middleware.security] /core/logs access from core_ssh
22-07-13 14:03:31 ERROR (MainThread) [supervisor.homeassistant.core] Home Assistant has crashed!
22-07-13 14:03:31 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.CORE / None
22-07-13 14:03:31 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REPAIR - ContextType.CORE / None
22-07-13 14:03:31 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 2 add-ons
22-07-13 14:03:33 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-configurator with version 5.3.3
22-07-13 14:03:34 INFO (SyncWorker_3) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/node-red/aarch64 with version 11.1.1
22-07-13 14:03:38 INFO (MainThread) [supervisor.api.middleware.security] /host/logs access from core_ssh
22-07-13 14:03:39 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-07-13 14:03:39 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-07-13 14:03:39 INFO (MainThread) [supervisor.host.info] Updating local host information
22-07-13 14:03:39 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-07-13 14:03:39 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-07-13 14:03:39 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-07-13 14:03:39 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-07-13 14:03:39 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
22-07-13 14:03:39 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-07-13 14:03:39 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-07-13 14:03:39 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-07-13 14:03:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-07-13 14:03:40 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-07-13 14:03:40 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-07-13 14:03:40 INFO (MainThread) [supervisor.host.services] Updating service information
22-07-13 14:03:40 INFO (MainThread) [supervisor.host.network] Updating local network information
22-07-13 14:03:40 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-07-13 14:03:40 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-07-13 14:03:41 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-07-13 14:03:41 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-07-13 14:03:41 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-07-13 14:05:46 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from core_ssh
22-07-13 14:08:07 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from core_ssh
22-07-13 14:08:13 INFO (MainThread) [supervisor.api.middleware.security] /os/info access from core_ssh
22-07-13 14:08:17 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from core_ssh
22-07-13 14:08:25 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from core_ssh
22-07-13 14:08:48 INFO (MainThread) [supervisor.api.middleware.security] /core/start access from core_ssh
22-07-13 14:08:48 INFO (SyncWorker_2) [supervisor.docker.interface] Starting homeassistant
22-07-13 14:08:49 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-07-13 14:09:04 ERROR (MainThread) [supervisor.homeassistant.core] Home Assistant has crashed!
22-07-13 14:09:09 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from core_ssh
22-07-13 14:12:39 INFO (MainThread) [supervisor.api.middleware.security] /os/info access from core_ssh
22-07-13 14:13:07 INFO (MainThread) [supervisor.api.middleware.security] /dns/info access from core_ssh
22-07-13 14:16:19 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from core_ssh
22-07-13 14:23:32 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from core_ssh
22-07-13 14:24:04 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from core_ssh
22-07-13 14:26:34 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from core_ssh
22-07-13 14:27:11 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from core_ssh
22-07-13 14:28:00 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from core_ssh
22-07-13 14:30:53 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from core_ssh
22-07-13 14:31:45 INFO (MainThread) [supervisor.api.middleware.security] /os/info access from core_ssh
22-07-13 14:32:15 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from core_ssh
22-07-13 14:32:29 INFO (MainThread) [supervisor.api.middleware.security] /docker/info access from core_ssh
22-07-13 14:33:29 INFO (MainThread) [supervisor.api.middleware.security] /cli/info access from core_ssh
22-07-13 14:33:36 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from core_ssh
22-07-13 14:33:53 INFO (MainThread) [supervisor.api.middleware.security] /core/logs access from core_ssh
22-07-13 14:34:29 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from core_ssh
OS Info
board: rpi4-64
boot: A
data_disk: /dev/mmcblk0p8
version: "8.2"
version_latest: "8.2"
I just updated today as well and run into a loop…
[14:44:09] INFO: Home Assistant Core finish process exit code 256
[14:44:09] INFO: Home Assistant Core finish process received signal 11
[14:44:10] INFO: Home Assistant Core finish process exit code 256
[14:44:10] INFO: Home Assistant Core finish process received signal 11
[14:44:11] INFO: Home Assistant Core finish process exit code 256
[14:44:11] INFO: Home Assistant Core finish process received signal 11
It is looping indefinitely with exit code 256 and signal 11. I am running HA core in docker.
I reverted back to 2022.5 and it boots. I think my issue might be related to the Python 3.10 update in HA 2022.7
how can you revert to another version if the application doesnt load? is this something we can do in the “emergency console”?
After upgrade my device got locked with the following errors:
“Cannot connect to the Docker deamon at unix:///var/run/docker.sock. Is the docker deamon running?”
“[WARN] Home Assistant CLI not starting! Jump into emergency console…”
I’m running HA Core in Docker so I can specify the version of the image to use. In HA Supervised I’m not sure how you can recover your instance. Did you make a backup? If so, you could boot a fresh install then restore your backup.
I always tick the make backup checkbox during upgrade, so hopefully I have a backup plan
it seems that my sda1 device cannot be mounted, it is suggesting I mount it with noload, but here I am outside of my knowledge area
Yeah there is definitely an issue. I’ve been looking for answers and I saw a ton of errors about 3.10. Reverted to tag 2022.5 as @Wetzel402 mentioned and I am back. Thank you!
Wait! What! There’s an “emergency console”?
I was able to recover with an older backup via cli with the SSH add-on. Where the core version is 2021.5.1. But same versions of OS and Supervisor.
I’ve tried to install every subversion of 2022.7 on Docker (QNAP NAS).
They show the same problem:
It is looping infinitely.
The last subversion of 2022.6 (2022.6.7) is working well.
What is the exact problem? How we can solve it?
I have been trying to get this to work on a new raspberry pi with Rocky Linux and podman for many hours. It looks like the was a issue with the image which is a little hard to swallow.
When looking at other post the fix it editing the ‘stable’ in the section that calls out what gets downloaded and installed. homeassistant/home-assistant:stable
The other post I found mensioned a different download, but I like the solution in this post. Simply edit :stable to :2022-5
The code I used is below
podman run -d \
  --name homeassistant \
  --privileged \
  --restart=unless-stopped \
  -e TZ=America/Chicago \
  -v /:/config \
  --network=host \
At least for some of us it appears the issue is related to running an old Linux Kernel.
HELP: Has similar issue like this as well running a docker container:
[15:38:10] INFO: Home Assistant Core finish process exit code 1
[15:38:10] INFO: Home Assistant Core service shutdown
[15:38:10] INFO: Home Assistant Core finish process exit code 256
[15:38:10] INFO: Home Assistant Core finish process received signal 15
The last known working version for armhf devices is 2022.6.7.
There is an open github issue here. I need to try to build HA on my machine but haven’t gotten there yet. Anyone with an armhf system is welcome to build a newer version of HA and see if it boots.
The arm32v7 version of the latest update of HA is working for me now where the homeassistant images were not. Might work for others
https://hub.docker.com/layers/linuxserver/homeassistant/arm32v7-2023.1.0/images/sha256-31b3658f613647409f4cf5fe864dbb7263dad021b9a845ec521cd9eaa0f25471?context=explore
It was discovered the linuxserver.io image uses different wheels and does work for those on arm32v7. It seems there is still an issue to prove out for arm32v6 though.
It should also be noted the in house HA image still doesn’t work. The HA team will likely need to rebuild wheels.
This problem was with incorrect work of auditwheel+patchelf.
Two LOAD sections in green color with incorrect alignment in patched libries (1000 instead 10000).
When the patch will be accepted and the Home Assistant+wheels devs take the new version of patchelf > 0.17.2 and rebuild the Home Assistant image and wheels we will have a working version again.
