Home Assistant core Fails to start
I am running Home assistant core in docker on unraid using linuxserver.io packages. I was recently away for a week and when I returned, Home Assistant was no longer functioning. This is what I see in the logs:
2024-08-31 19:29:40.565 ERROR (MainThread) [root] Uncaught exception
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "/usr/local/lib/python3.12/site-packages/homeassistant/__main__.py", line 223, in <module>
    sys.exit(main())
  File "/usr/local/lib/python3.12/site-packages/homeassistant/__main__.py", line 209, in main
    exit_code = runner.run(runtime_conf)
  File "/usr/local/lib/python3.12/site-packages/homeassistant/runner.py", line 190, in run
    return loop.run_until_complete(setup_and_run_hass(runtime_config))
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 687, in run_until_complete
    return future.result()
  File "/usr/local/lib/python3.12/site-packages/homeassistant/runner.py", line 158, in setup_and_run_hass
    hass = await bootstrap.async_setup_hass(runtime_config)
  File "/usr/local/lib/python3.12/site-packages/homeassistant/bootstrap.py", line 314, in async_setup_hass
    config_dict = await conf_util.async_hass_config_yaml(hass)
  File "/usr/local/lib/python3.12/site-packages/homeassistant/config.py", line 486, in async_hass_config_yaml
    await merge_packages_config(hass, config, core_config.get(CONF_PACKAGES, {}))
  File "/usr/local/lib/python3.12/site-packages/homeassistant/config.py", line 1046, in merge_packages_config
    _validate_package_definition(pack_name, pack_conf)
  File "/usr/local/lib/python3.12/site-packages/homeassistant/config.py", line 1001, in _validate_package_definition
    cv.slug(name)
  File "/usr/local/lib/python3.12/site-packages/homeassistant/helpers/config_validation.py", line 580, in slug
    slg = util_slugify(str_value)
  File "/usr/local/lib/python3.12/site-packages/homeassistant/util/__init__.py", line 45, in slugify
    slug = unicode_slug.slugify(text, separator=separator)
TypeError: slugify() got an unexpected keyword argument 'separator'
The only thing that I have tried so far was to go back to an earlier version of the docker linuxserver.io as it had been updated while I was away and it made no difference.
I do not know what to do to troubleshoot this issue and am hoping someone can point me in the right direction.
