If something else is happening or missing, it’s not visible in the screenshot you send. The actual cause of error is not there. It’s only pip reporting that the rustc subprocess terminated unexpectedly, but we don’t know why it did.
I have been using for a while a 5G Nokia phone as a modem and since it’s basically it’s only function, I decided to install homeassistant on it (I don’t have anymore my pi3B).
I tried following the instructions here, tried many things actually, but i’m always stuck on cryptography and orjson.
My mobile uses an aarch64 platform. The full details about versions are:
My latest problem with orjson is the code below. I’ve tried to run it running before export CARGO_BUILD_TARGET="$(rustc -Vv | grep “host” | awk ‘{print $2}’)" but it made no diference.
I have attached the error for cryptography here, since is too big to fit on this post.
Any ideas on what else could I try?
~ $ pip install orjson
WARNING: pip is being invoked by an old script wrapper. This will fail in a future version of pip.
Please see https://github.com/pypa/pip/issues/5599 for advice on fixing the underlying issue.
To avoid this problem you can invoke Python with '-m pip' instead of running pip directly.
Collecting orjson
Using cached orjson-3.8.0.tar.gz (949 kB)
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing metadata (pyproject.toml) ... done
Building wheels for collected packages: orjson
Building wheel for orjson (pyproject.toml) ... error
error: subprocess-exited-with-error
× Building wheel for orjson (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [44 lines of output]
Running `maturin pep517 build-wheel -i /data/data/com.termux/files/usr/bin/python --compatibility off`
Compiling target-lexicon v0.12.4
Compiling autocfg v1.1.0
Compiling serde v1.0.144
Compiling once_cell v1.13.1
Compiling version_check v0.9.4
Compiling rustversion v1.0.9
Compiling libc v0.2.132
Compiling ryu v1.0.11
Compiling cfg-if v1.0.0
Compiling itoa v1.0.3
Compiling encoding_rs v0.8.31
Compiling cc v1.0.73
Compiling serde_json v1.0.85 (/data/data/com.termux/files/usr/tmp/pip-install-wvn6vp_r/orjson_9fff109b17ae4ad790eb0044f422b60f/local_dependencies/serde_json)
Compiling associative-cache v1.0.1
Compiling simdutf8 v0.1.4
Compiling smallvec v1.9.0
Compiling bytecount v0.6.3
Compiling ahash v0.8.0
Compiling num-traits v0.2.15
Compiling num-integer v0.1.45
Compiling pyo3-build-config v0.17.0
Compiling castaway v0.2.2
Compiling chrono v0.4.19
Compiling pyo3-ffi v0.17.0
Compiling orjson v3.8.0 (/data/data/com.termux/files/usr/tmp/pip-install-wvn6vp_r/orjson_9fff109b17ae4ad790eb0044f422b60f)
Compiling arrayvec v0.7.2
Compiling compact_str v0.6.1
Compiling beef v0.5.2
error: could not compile `orjson` due to 2 previous errors
💥 maturin failed
Caused by: Failed to build a native library through cargo
Caused by: Cargo build finished with "exit status: 101": `"cargo" "rustc" "--release" "--target" "aarch64-linux-android" "--message-format" "json" "--lib"`
📦 Including license file "LICENSE-APACHE"
📦 Including license file "LICENSE-MIT"
🔗 Found pyo3-ffi bindings
🐍 Found CPython 3.10 at /data/data/com.termux/files/usr/bin/python
error: failed to prepare thin LTO module: Opaque pointers are only supported in -opaque-pointers mode (Producer: 'LLVM15.0.1' Reader: 'LLVM 15.0.1')
error: aborting due to previous error
Error: command ['maturin', 'pep517', 'build-wheel', '-i', '/data/data/com.termux/files/usr/bin/python', '--compatibility', 'off'] returned non-zero exit status 1
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for orjson
Failed to build orjson
ERROR: Could not build wheels for orjson, which is required to install pyproject.toml-based projects
All I can say is that this seems to be the cause, it’s found on both logs. Never had that before, though.
I see that it’s using LLVM/clang version 15, which seems to be a recent upgrade in Termux from this week. Mine is still using version 14. I see there were several issues of compatibility with this upgrade, some packages not up to date, some libraries not updated to match, etc.
So I’d say you’re unlucky and fell exactly in the wrong time.
That said, your error doesn’t seem related to Termux per se, more to the new LLVM version. Maybe we need to find a way to activate those opaque-pointers?
I mean it’s embedded in the Termux package, and will most likely be this way for the future, so I’m not sure if it’s the way to go, rather to work around that or fix it.
pip download orjson==3.7.11
tar xvf orjson-3.7.11.tar.gz
cd orjson-3.7.11
nano Cargo.toml
commented out lto = "thin"
maturin build --release --strip
cd ..
rm orjson-3.7.11.tar.gz
tar -czvf orjson-3.7.11.tar.gz orjson-3.7.11
cryptography
pip download cryptography==37.0.4
tar xvf cryptography-37.0.4.tar.gz
cd cryptography-37.0.4/src/rust
nano Cargo.toml
cd
cd ../../../
rm cryptography-37.0.4.tar.gz
tar -czvf cryptography-37.0.4.tar.gz cryptography-37.0.4
then i followed with installation steps, but manually installing orjson and cryptography:
Thank you for the guide and support! Comments from @Gnoupi and @leofuscaldi were very useful!
Managed to install it on an Asus ZenPad Z500M running Android 7. Did not have to install lineage OS. Also installed it in parallel on a OnePlus 7 Pro with LineageOS 18.1
Managed to connect multiple devices, works pretty well. I still have these issues in the log, if someone fixed these already, please share
Setup failed for default_config: (DependencyError(...), 'Could not setup dependencies: hardware')
October 2, 2022 at 11:29:43 PM – (ERROR) setup.py
Unable to set up dependencies of default_config. Setup failed for dependencies: hardware
Error during setup of component hardware
October 2, 2022 at 11:29:41 PM – (ERROR) components/hardware/websocket_api.py
Hey, I’m rather new to Linux in general, so please bear with me. I was having issues installing any packages that needed to generate a wheel, and came across this forum. I was trying to install cryptography through termux. I’ve never used home assistant, so my use case may differ here. I did a little research and found I could set an environment variable to force rustc to not use the lto flag, something like
export RUSTFLAGS="-C lto=n"
If this is a dumb way to do this, please let me know, but I was finally able to install what I needed after setting the variable.
Collecting orjson==3.7.11
Using cached orjson-3.7.11.tar.gz (946 kB)
Installing build dependencies ... error
× pip subprocess to install build dependencies did not run successfully.
│ exit code: 1
╰─> [58 lines of output]
Collecting maturin<0.14,>=0.13
Using cached maturin-0.13.5.tar.gz (150 kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'done'
Collecting tomli>=1.1.0
Using cached tomli-2.0.1-py3-none-any.whl (12 kB)
Building wheels for collected packages: maturin
Building wheel for maturin (pyproject.toml): started
Building wheel for maturin (pyproject.toml): finished with status 'error'
× Building wheel for maturin (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [34 lines of output]
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-aarch64-cpython-310
creating build/lib.linux-aarch64-cpython-310/maturin
copying maturin/__main__.py -> build/lib.linux-aarch64-cpython-310/maturin
copying maturin/__init__.py -> build/lib.linux-aarch64-cpython-310/maturin
copying maturin/import_hook.py -> build/lib.linux-aarch64-cpython-310/maturin
running egg_info
creating maturin.egg-info
writing maturin.egg-info/PKG-INFO
writing dependency_links to maturin.egg-info/dependency_links.txt
writing requirements to maturin.egg-info/requires.txt
writing top-level names to maturin.egg-info/top_level.txt
writing manifest file 'maturin.egg-info/SOURCES.txt'
reading manifest file 'maturin.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
running build_ext
running build_rust
error: rustup could not choose a version of rustc to run, because one wasn't specified explicitly, and no default is configured.
Have already installed the Rust and Cargo packages, so I’m at a loss here.
Did you install rustup? I had that issue too on termux (sandboxed Linux app for Android), rustup doesn’t support termux based builds. I think I’d installed rust with my package manager, and then installed rustup on top of it (not good lol). Try doing rustup self uninstall and then install rust (if you haven’t already) through your normal package manager, then try again.
So I managed to successfully install the recent version of HA on my Android11 tablet, without any errors.
However running the HA with hass -v gives me the following errors
Running HA in safe mode works fine.
Can someone please guide? Thanks in advance.
2022-10-10 21:30:19.962 ERROR (MainThread) [homeassistant.setup] [u]**[u]**Error during setup of component hardware**[/u]**[/u]
File "/data/data/com.termux/files/home/hass/lib/python3.10/site-packages/homeassistant/setup.py", line 235, in _async_setup_component
result = await task
File "/data/data/com.termux/files/home/hass/lib/python3.10/site-packages/homeassistant/components/hardware/__init__.py", line 15, in async_setup
await websocket_api.async_setup(hass)
File "/data/data/com.termux/files/home/hass/lib/python3.10/site-packages/homeassistant/components/hardware/websocket_api.py", line 36, in async_setup
ha_psutil=await hass.async_add_executor_job(ha_psutil.PsutilWrapper),
File "/data/data/com.termux/files/usr/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/data/data/com.termux/files/home/hass/lib/python3.10/site-packages/psutil_home_assistant/__init__.py", line 15, in __init__
psutil_spec.loader.exec_module(psutil_module)
File "<frozen importlib._bootstrap_external>", line 883, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/data/data/com.termux/files/home/hass/lib/python3.10/site-packages/psutil/__init__.py", line 42, in <module>
from . import _common
File "/data/data/com.termux/files/home/hass/lib/python3.10/site-packages/psutil/__init__.py", line 102, in <module>
from . import _pslinux as _psplatform
File "/data/data/com.termux/files/home/hass/lib/python3.10/site-packages/psutil/_pslinux.py", line 26, in <module>
from . import _psutil_linux as cext
ImportError: dlopen failed: cannot locate symbol "ethtool_cmd_speed" referenced by "/data/data/com.termux/files/home/hass/lib/python3.10/site-packages/psutil/_psutil_linux.cpython-310.so"...
2022-10-10 21:30:19.986 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.5 seconds
2022-10-10 21:30:19.994 INFO (MainThread) [homeassistant.setup] Setup of domain schedule took 0.5 seconds
2022-10-10 21:30:19.997 INFO (MainThread) [homeassistant.setup] Setup of domain input_text took 0.5 seconds
2022-10-10 21:30:20.027 INFO (MainThread) [homeassistant.setup] Setting up tts
2022-10-10 21:30:20.030 INFO (MainThread) [homeassistant.setup] Setting up sensor
2022-10-10 21:30:20.032 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.0 seconds
2022-10-10 21:30:20.050 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 0.5 seconds
2022-10-10 21:30:20.063 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 0.5 seconds
2022-10-10 21:30:20.065 INFO (MainThread) [homeassistant.setup] Setup of domain input_button took 0.5 seconds
2022-10-10 21:30:20.082 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.energy
2022-10-10 21:30:20.086 INFO (SyncWorker_2) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2022-10-10 21:30:20.194 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2022-10-10 21:30:20.198 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.2 seconds
2022-10-10 21:30:20.202 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.0 seconds
2022-10-10 21:30:20.206 INFO (MainThread) [homeassistant.setup] Setting up notify
2022-10-10 21:30:20.207 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds
2022-10-10 21:30:20.214 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: hardware
[u]**2022-10-10 21:30:20.225 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: (DependencyError(...), 'Could not setup dependencies: hardware')**[/u]
2022-10-10 21:30:20.233 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2022-10-10 21:30:40.029 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
2022-10-10 21:30:40.040 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Home' for met integration not ready yet: Update failed: ; Retrying in background
2022-10-10 21:30:40.050 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 26.50s
2022-10-10 21:30:40.052 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2022-10-10 21:30:40.082 INFO (MainThread) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
CRITICAL: Can't open /proc/net/dev !
2022-10-10 21:30:41.977 CRITICAL (SyncWorker_0) [scapy.loading] Can't open /proc/net/dev !
CRITICAL: Can't open /proc/net/route !
2022-10-10 21:30:41.998 CRITICAL (SyncWorker_0) [scapy.loading] Can't open /proc/net/route !
2022-10-10 21:30:42.006 CRITICAL (SyncWorker_0) [scapy.loading] Can't open /proc/net/dev !
2022-10-10 21:30:42.291 WARNING (SyncWorker_1) [pyroute2.netlink.rtnl.tcmsg.common] tcmsg: [Errno 13] Permission denied: '/proc/net/psched'
2022-10-10 21:30:42.307 WARNING (SyncWorker_1) [pyroute2.netlink.rtnl.tcmsg.common] the tc subsystem functionality is limited
2022-10-10 21:30:50.614 ERROR (MainThread) [homeassistant.components.homeassistant_alerts] Timeout fetching homeassistant_alerts data
2022-10-10 21:31:00.102 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
^C2022-10-10 21:31:01.188 INFO (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Pool recreatingte code here
“A very long log” unfortunately does not help much when it comes to finding a solution. Unless you know what to find in the log and can provide it in your post, you’d have to post all the relevant log.
