Can someone tell me if scrape runs on the home assistant core platform?
Integration is running and is listed in the integration overview.
However, I’m not sure if it works in the core at all.
Attached is the error log, unfortunately I can’t do anything with this.
Logger: homeassistant.components.sensor
Source: components/scrape/sensor.py:128
Integration: Sensor (documentation, issues)
First occurred: 20:43:38 (1 occurrences)
Last logged: 20:43:38
scrape: Error on device update!
File “/volume1/@appstore/homeassistant/env/lib/python3.8/site-packages/homeassistant/helpers/entity_platform.py”, line 431, in _async_add_entity
await entity.async_device_update(warning=False)
File “/volume1/@appstore/homeassistant/env/lib/python3.8/site-packages/homeassistant/helpers/entity.py”, line 633, in async_device_update
await task
File “/volume1/@appstore/homeassistant/env/lib/python3.8/site-packages/homeassistant/components/scrape/sensor.py”, line 139, in async_update
await self._async_update_from_rest_data()
File “/volume1/@appstore/homeassistant/env/lib/python3.8/site-packages/homeassistant/components/scrape/sensor.py”, line 152, in _async_update_from_rest_data
value = await self.hass.async_add_executor_job(self._extract_value)
File “/var/packages/python38/target/lib/python3.8/concurrent/futures/thread.py”, line 57, in run
File “/volume1/@appstore/homeassistant/env/lib/python3.8/site-packages/homeassistant/components/scrape/sensor.py”, line 128, in _extract_value
tag = raw_data.select(self._select)[self._index]
File “/volume1/@appstore/homeassistant/env/lib/python3.8/site-packages/bs4/element.py”, line 1865, in select
raise NotImplementedError(
NotImplementedError: Cannot execute CSS selectors because the soupsieve package is not installed.
