Hi, Troy Thanks for your response.
I gave the bomradarloop install and got and got the following. Now thinking about it a bit more I actually followed your freenas 11.2 guide to set this up but have since upgraded to 11.3. Maybe I should just reinstall using your community plugin and migrate configs. I also upgraded the homeassistant jail to 11.3 using the āiocage upgrade -r 11.3-RELEASE homeassistantā this looks like it messed up my pkg versions so ffmpeg wonāt install either.
root@homeassistant:~ # su - hass
[hass@homeassistant ~]$ source /srv/homeassistant/bin/activate
(homeassistant) [hass@homeassistant ~]$ pip3 install --upgrade wheel
Collecting wheel
Using cached wheel-0.34.2-py2.py3-none-any.whl (26 kB)
Installing collected packages: wheel
Attempting uninstall: wheel
Found existing installation: wheel 0.33.6
Uninstalling wheel-0.33.6:
Successfully uninstalled wheel-0.33.6
Successfully installed wheel-0.34.2
(homeassistant) [hass@homeassistant ~]$ pip3 install --upgrade bomradarloop==0.1.4
Collecting bomradarloop==0.1.4
Using cached bomradarloop-0.1.4-py3-none-any.whl (8.8 kB)
Collecting Pillow
Using cached Pillow-7.1.2.tar.gz (38.9 MB)
Requirement already satisfied, skipping upgrade: requests in /srv/homeassistant/lib/python3.7/site-packages (from bomradarloop==0.1.4) (2.23.0)
Requirement already satisfied, skipping upgrade: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in /srv/homeassistant/li b/python3.7/site-packages (from requests->bomradarloop==0.1.4) (1.25.9)
Requirement already satisfied, skipping upgrade: idna<3,>=2.5 in /srv/homeassistant/lib/python3.7/site-packages ( from requests->bomradarloop==0.1.4) (2.8)
Requirement already satisfied, skipping upgrade: certifi>=2017.4.17 in /srv/homeassistant/lib/python3.7/site-pack ages (from requests->bomradarloop==0.1.4) (2020.4.5.1)
Requirement already satisfied, skipping upgrade: chardet<4,>=3.0.2 in /srv/homeassistant/lib/python3.7/site-packa ges (from requests->bomradarloop==0.1.4) (3.0.4)
Building wheels for collected packages: Pillow
Building wheel for Pillow (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: /srv/homeassistant/bin/python3.7 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip -install-yb75oapt/Pillow/setup.py'"'"'; __file__='"'"'/tmp/pip-install-yb75oapt/Pillow/setup.py'"'"';f=getattr(to kenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compil e(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-fiukk7ob
cwd: /tmp/pip-install-yb75oapt/Pillow/
Complete output (172 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7
creating build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageFilter.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageDraw.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageFile.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImagePath.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/XpmImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/features.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ExifTags.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageQt.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/DcxImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/FontFile.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/_binary.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/PixarImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/CurImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/TiffTags.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/Jpeg2KImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/TarIO.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImagePalette.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/MicImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/SpiderImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/PdfParser.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageFont.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/Hdf5StubImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/SunImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageChops.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageGrab.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/WalImageFile.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/_tkinter_finder.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/SgiImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/FtexImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/WmfImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageTk.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/__main__.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/BlpImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageMode.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/McIdasImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/GimpGradientFile.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/TiffImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/EpsImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/XbmImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/WebPImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/BmpImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageStat.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/GdImageFile.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/XVThumbImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/IptcImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageWin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/PalmImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageEnhance.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/MpoImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/IcnsImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/_version.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageTransform.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/JpegImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageOps.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/GifImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/GbrImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/PdfImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/IcoImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageSequence.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/PcfFontFile.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageMath.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/MspImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/GribStubImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/BufrStubImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageShow.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/PcxImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/__init__.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/FliImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/TgaImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/PcdImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/PngImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/BdfFontFile.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageMorph.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/DdsImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ContainerIO.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/FpxImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/GimpPaletteFile.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/PSDraw.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageCms.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/JpegPresets.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/PsdImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/FitsStubImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageColor.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/PaletteFile.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImtImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/ImageDraw2.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/PpmImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/_util.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/Image.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/PyAccess.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
copying src/PIL/MpegImagePlugin.py -> build/lib.freebsd-11.3-RELEASE-p7-amd64-3.7/PIL
running egg_info
writing src/Pillow.egg-info/PKG-INFO
writing dependency_links to src/Pillow.egg-info/dependency_links.txt
writing top-level names to src/Pillow.egg-info/top_level.txt
reading manifest file 'src/Pillow.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '*.c'
warning: no files found matching '*.h'
warning: no files found matching '*.sh'
warning: no previously-included files found matching '.appveyor.yml'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching '.editorconfig'
warning: no previously-included files found matching '.readthedocs.yml'
warning: no previously-included files found matching 'azure-pipelines.yml'
warning: no previously-included files found matching 'codecov.yml'
warning: no previously-included files matching '.git*' found anywhere in distribution
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files matching '*.so' found anywhere in distribution
no previously-included directories found matching '.azure-pipelines'
no previously-included directories found matching '.ci'
writing manifest file 'src/Pillow.egg-info/SOURCES.txt'
running build_ext
The headers or library files could not be found for jpeg,
a required dependency when compiling Pillow from source.
Please see the install instructions at:
https://pillow.readthedocs.io/en/latest/installation.html
File "/tmp/pip-install-yb75oapt/Pillow/setup.py", line 899, in <module>
zip_safe=not (debug_build() or PLATFORM_MINGW),
File "/srv/homeassistant/lib/python3.7/site-packages/setuptools/__init__.py", line 145, in setup
return distutils.core.setup(**attrs)
File "/usr/local/lib/python3.7/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/local/lib/python3.7/distutils/dist.py", line 966, in run_commands
self.run_command(cmd)
File "/usr/local/lib/python3.7/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/srv/homeassistant/lib/python3.7/site-packages/wheel/bdist_wheel.py", line 223, in run
self.run_command('build')
File "/usr/local/lib/python3.7/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/usr/local/lib/python3.7/distutils/command/build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/usr/local/lib/python3.7/distutils/command/build_ext.py", line 339, in run
self.build_extensions()
File "/tmp/pip-install-yb75oapt/Pillow/setup.py", line 694, in build_extensions
raise RequiredDependencyException(f)
__main__.RequiredDependencyException: jpeg
File "<string>", line 1, in <module>
File "/tmp/pip-install-yb75oapt/Pillow/setup.py", line 914, in <module>
raise RequiredDependencyException(msg)
ERROR: Failed building wheel for Pillow
Running setup.py clean for Pillow
Failed to build Pillow
Installing collected packages: Pillow, bomradarloop
Running setup.py install for Pillow ... error
command: /srv/homeassistant/bin/python3.7 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/p ip-install-yb75oapt/Pillow/setup.py'"'"'; __file__='"'"'/tmp/pip-install-yb75oapt/Pillow/setup.py'"'"';f=getattr( tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(comp ile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-5uqv_foh/install-record.txt --single-versi on-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.7/Pillow
Complete output (174 lines):
running install
running build
running build_py
creating build
running egg_info
running build_ext
dist.run_commands()
cmd_obj.run()
File "/srv/homeassistant/lib/python3.7/site-packages/setuptools/command/install.py", line 61, in run
return orig.install.run(self)
File "/usr/local/lib/python3.7/distutils/command/install.py", line 545, in run
cmd_obj.run()
cmd_obj.run()
ERROR: Command errored out with exit status 1: /srv/homeassistant/bin/python3.7 -u -c 'import sys, setuptools, to kenize; sys.argv[0] = '"'"'/tmp/pip-install-yb75oapt/Pillow/setup.py'"'"'; __file__='"'"'/tmp/pip-install-yb75oap t/Pillow/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-5uqv_foh/ install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/sit e/python3.7/Pillow Check the logs for full command output.
root@homeassistant:~ # pkg install ffmpeg
Updating FreeBSD repository catalogue...
[homeassistant] Fetching meta.txz: 100% 916 B 0.9kB/s 00:01
pkg: repository meta /var/db/pkg/FreeBSD.meta has wrong version 2
repository FreeBSD has no meta file, using default settings
[homeassistant] Fetching packagesite.txz: 100% 6 MiB 1.1MB/s 00:06
pkg: Repository FreeBSD load error: meta cannot be loaded No error: 0
Unable to open created repository FreeBSD
Unable to update repository FreeBSD
Error updating repositories!
