Home Assistant Core -- TrueNAS CORE Community Plugin
Hello, thanks a lot for you answer, works perfectly :heart_eyes:
Ohh it will be perfect.
Thanks again for all the job you doing.
I managed to add my 4 poe cameras today, everything is fine for me :slight_smile:
Good week end to everybody
Ok, so from what I understand.
If I use the TrueNAS gui to update the jail, it will update your files(rc.d/startup, etc).
And if I want to update HA itself, I can do it from the Jailā€™s shell?
Yes, also using the TrueNAS gui updates the jail its self - basically the same as running pkg update and pkg upgrade
You got it!
Cool.
Iā€™ve been having some problems with my current supervised Hassio, so I will give this TrueNAS a go tonight :slight_smile:
Hi there, thanks for instructions, upgrading python worked ok but when running the reinstall command I get:
/usr/local/etc/rc.d/homeassistant: unknown directive 'reinstall'.
Usage: /usr/local/etc/rc.d/homeassistant [fast|force|one|quiet](start|stop|restart|rcvar|enabled|describe|extracommands|check_config|restart|test|upgrade|status|poll)
So I tried upgrade, it upgraded from 0.116 to 0.116.2 but when I test the homeassitant it still shows python version 3.7.6. How to overcome that?
Ok, so I have a question that is a little offtopic, but still related.
Where can I set up users for your mosquitto TrueNAS plugin?
Hi @adorobis
Seems like your using an older version of the rc.d script. Please update the plugin itself using Plugins > (select your Home Assistant jail ) > UPDATE from the FreeNAS UI ā€“ after updating the plugin itself, the following should work. (when asked, answer YES to also clear the pip cache)
iocage console $_JAIL_NAME
# Press 0 to exit the menu
sysrc homeassistant_python=/usr/local/bin/python3.8
service homeassistant reinstall
@YamiFrankc, Iā€™m glad you asked - There have been some recent contributions to that plugin by @sam-harry, allowing some basic configuration using iocage set commands!
Using the TrueNAS shell, NOT the jail shell
  • Change allow_anonymous setting to false
iocage set -P allow_anonymous=false $JAIL_NAME
  • Add users to the default password file
iocage set -P adduser=username,password $JAIL_NAME
  • Delete users from the default password file
iocage set -P deluser=username $JAIL_NAME
mosquitto can also be configured from inside the jail, as shown in the official docs.
iocage console $JAIL_NAME
The configuration file is located at
/usr/local/etc/mosquitto/mosquitto.conf
Examples using mosquitto_passwd
  • Add a user to a new password file
mosquitto_passwd  `-c`  /usr/local/etc/mosquitto/pwfile  `ral`
  • Delete a user from a password file
mosquitto_passwd  `-D`  /usr/local/etc/mosquitto/pwfile  `ral`
@troy thanks for quick reply. The update fails and rolls back from snapshot. The last message shown is pkg.FreeBSD.org could not be reached via DNS, check hacore's network configuration
But I donā€™t think it is correct message as I can access that domain from the jail. Where are logs stored so I could check what is going on?
@troy
Iā€™ve found it. I should have updated the plugin from jails menu not from plugins (or is it the same?). Anyway, the second attempt worked ok and Iā€™m on python 3.8.6 now :slight_smile:
But after the update I have some other errors:
INFO:homeassistant.util.package:Attempting install of PyNaCl==1.3.0
ERROR: Failed building wheel for PyNaCl
ERROR: Could not build wheels for PyNaCl which use PEP 517 and cannot be installed directly
and in the log:
2020-10-13 18:39:53 ERROR (MainThread) [homeassistant.setup] Setup failed for mobile_app: Requirements for mobile_app not found: ['PyNaCl==1.3.0'].
Any suggestions? Tried to install this package manually with pip but with the same effect.
Thatā€™s a really good questionā€¦ I donā€™t ever recall seeing that documented, nor have I come across any iocage logs myself. Typically, when I need to see whatā€™s happening, I ssh into my NAS and run ā€˜iocageā€™ commands from the console. In this case, to update an installed plugin.
iocage update -P $JAIL_NAME
I thought it was the same but I could be wrong, either way Iā€™m glad it worked the second time.
FreeBSD version 11.3-RELEASE-p14 seems to have some issues with gcc
/lib/libc.so.7: version FBSD_1.6 required by /usr/local/bin/gcc not found
Fortunately using gcc9 seems to resolve the PyNaCl issue. I have a pull request to switch the plugin manifest to gcc9. For now, I think this should do the trick (gcc9 is already installed, so we only need to remove gcc)
pkg delete gcc
service homeassistant install --force-reinstall --no-cache PyNaCl==1.3.0
service homeassistant restart
Great, so this fixed the PyNaCl issue. :slight_smile: Now there is one more thing: the appdaemon does not start after the python update. Have no clue yet where to look for solution but Iā€™m assuming some dependencies with python version. Strange thing here:
root@hacore:~ # service appdaemon test
Testing virtualenv...
 CWD: /srv/appdaemon
 Python 3.7.9
 AppDaemon 4.0.5
root@hacore:~ # sysrc appdaemon_python
appdaemon_python: /usr/local/bin/python3.8
Need some more help :slight_smile:
Ah, that was easy :slight_smile:
service appdaemon install
did the trick. Uff. So Iā€™m almost done :slight_smile: Now just need to fix my own service to control ventilation unit via serial port, stopped working after python upgrade as well. Maybe you would have a suggestion? When I try to run it in python3.7 I get error:
root@hacore:/srv/ca350/bin # python3.7 ca350
* CA350 MQTT Home Assistant *
13-10-2020 18:29:54 WARNING: Opening serial port exception:
13-10-2020 18:29:54 WARNING: (<class 'AttributeError'>, AttributeError("module 'serial' has no attribute 'Serial'"), <traceback object at 0x801fb1d20>)
when running in python3.8 it canā€™t find the paho-mqtt component:
root@hacore:/srv/ca350/bin # python3.8 ca350
  File "ca350", line 26, in <module>
    import paho.mqtt.client as mqtt
ModuleNotFoundError: No module named 'paho'
the package is installed but python3.8 canā€™t find itā€¦
Iā€™m wondering if appdaemon did not like combination appdaemon_python: /usr/local/bin/python3.8 and service appdaemon install to the existing (I assume was previously python3.7) virtualenv
Can you try again using the console menu - The command is simply menu - Then select 3 for the appdaemon menu. Number 8 should be remove - When appdaemon has been removed, number 8 will change to install.
Just running the service appdaemon install solved the problem, all good now butā€¦ the test still shows the 3.7.9 virtual environment:
 CWD: /srv/appdaemon
 Python 3.7.9
 AppDaemon 4.0.5
OK, so Iā€™ve removed and installed using menu now it seems all fixed:
 CWD: /usr/local/share/appdaemon
 Python 3.8.6
 AppDaemon 4.0.5
I know why now, (had to go look at the post_install.sh)
This is because the python version is only used when creating a new virtualenv ā€“ The script will check for an existing virtaulenv at the location set by sysrc appdaemon_venv ā€“ If it finds an existing venv, it will use whatever version of python it was created with.
The test command should always be accurate to the python version inside the venv. This is because the command will actually run python --version from inside the activated venv
Thanks for your support @troy . This python upgrade was a bit painful, strange things were happening, also to my own service, some modules were installed but not seen by 3.8, some the other way round - seen by 3.8 but not by 3.7. Some service files stopped working although were working ok before the upgradeā€¦ Finally, all is back and running smoothly.
Fun Fact: It was this comment by @wmn79 that started this all
Always useful for others to share what you did to make it working. Iā€™m still working with an old jail version for which I used the ā€œALLOW UNSUPPORTED SYSTEM=trueā€ solution to keep it running. Need to make the switch to the new IOCAGE jails some time as well so all help is appreciated.
Haha, that is quite some time ago :smile:
And this plugin is about 800 lines of code, that still do the same thing as that first guide :rofl: ā€“ Only the python version has changed. Sometimes I wonder if we are actually any further ahead, or if this is just taking something simple and making it complicated :rofl:
