I’ve been attempting to update the home assistant core update. Everytime I run it, it fails to complete, and I have to pull the power plug and restart home assistant. I’ve tried this from the menu, and from the CLI. When I perform the update using the CLI, I can see it start running, then after several minutes, the cursor stops updating, and I can tell that the system is locked up. At this point, all I can do is perform a hard boot, by removing and reapplying power.
My system is built on an O-droid. I’ve never had any problem performing updates before this.
This is my HA core info:
arch: aarch64
audio_input: None
audio_output: None
backups_exclude_database: false
boot: true
image: ghcr.io/home-assistant/odroid-n2-homeassistant
ip_address: 172.30.32.1
machine: odroid-n2
port: 8123
ssl: false
update_available: true
version: 2024.5.3
version_latest: 2024.12.3
watchdog: true
