Home Assistant Core upgrade failed 2024.10.2 -> .3 or .4 [resolved]
I’m posting this in case it is of help to others. I could not get the automatic update for Home Assistant Core to work. I was running 2024.10.2 and was attempting to update to .3 and then .4.
I’m using a Raspberry Pi running the containerized install
Symptoms - When I would tell the system to update… it would take a really long time and then eventually would appear to crash the host and cause it to reboot.
Apparent Fix - I had a partial install of HACS on my system. This appears to be what was angering the update. To resolve the issue, I had to log in and remove all of the hold HACS files and directories. I used the terminal plugin and roughly followed the instructions in the below video, however I deleted any/all HACS associated files using terminal on my own box (versus using an external tool). I specifically had to delete all the hats files in ~config/.storage sub directory.
Once I did the above and rebooted (2x for good measure) the install was successful.
Hello flobst,
If one of the suggestions listed solves your problem, please consider clicking the solution button to close the thread. (even your own…)
