Home Assistant crashes / AdGuard unresponsive on raspberry pi 3
Hi everyone,
I have this re-occurring issue with my installation of Home Assistant onto my old Raspberry Pi 3 64bit that it either gets rebooted, crashes, or otherwise unresponsive and I only noticed it ever since I installed AdGuard add-on and configured it for my home router.
The reason I now notice it from time to time is that I don’t have Internet and that’s because the AdGuard DNS server on HA is unresponsive. It can happen once a week or once every 3 weeks, so very sporadic.
I tried replacing SD cards, and I tried different installations of Home Assistant too (as in, downgrading to older, potentially more stable installs) but the issue still repeats.
Is it a memory issue? the Raspberry Pi 3 model I have has 1GB and I have several add-ons:
  • AdGuard
  • Tailscale
  • File editor
  • Terminal SSH
and I also have the Zigbee Home Automation integration and maybe 8 others (speed test, sun, mobile app, google cast, HACS and a few integrations that aren’t initialized like failed setup for Android TV remote and Broadlink)
Here are the logs I collected when this was happening:
Host Logs:
2024-08-29 08:33:02.128 homeassistant systemd[1]: docker-5a16ecf3402e7644008f88de7204b970a2bbd021451681d6dfd9ae2868f0f425.scope: A process of this unit has been killed by the OOM killer.
2024-08-29 08:33:02.129 homeassistant systemd[1]: docker-5a16ecf3402e7644008f88de7204b970a2bbd021451681d6dfd9ae2868f0f425.scope: A process of this unit has been killed by the OOM killer.
2024-08-29 08:33:03.211 homeassistant kernel: nf_conntrack: nf_conntrack: table full, dropping packet
2024-08-29 08:33:26.329 homeassistant kernel: audit: type=1334 audit(1724920396.717:1072): prog-id=61 op=UNLOAD
2024-08-29 08:33:26.329 homeassistant kernel: usb 1-1.5: USB disconnect, device number 5
2024-08-29 08:33:26.330 homeassistant kernel: usb 1-1.5: new full-speed USB device number 6 using dwc_otg
2024-08-29 08:33:26.331 homeassistant kernel: usb 1-1.5: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
2024-08-29 08:33:26.331 homeassistant kernel: usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
2024-08-29 08:33:26.331 homeassistant kernel: usb 1-1.5: Product: ConBee II
2024-08-29 08:33:26.332 homeassistant kernel: usb 1-1.5: Manufacturer: dresden elektronik ingenieurtechnik GmbH
2024-08-29 08:33:26.332 homeassistant kernel: usb 1-1.5: SerialNumber: DE2429465
2024-08-29 08:33:26.333 homeassistant kernel: cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
2024-08-29 08:33:26.334 homeassistant kernel: usb 1-1.5: USB disconnect, device number 6
2024-08-29 08:33:26.334 homeassistant kernel: usb 1-1.5: new full-speed USB device number 7 using dwc_otg
2024-08-29 08:33:26.336 homeassistant kernel: usb 1-1.5: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
2024-08-29 08:33:26.337 homeassistant kernel: usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
2024-08-29 08:33:26.338 homeassistant kernel: usb 1-1.5: Product: ConBee II
2024-08-29 08:33:26.339 homeassistant kernel: usb 1-1.5: Manufacturer: dresden elektronik ingenieurtechnik GmbH
2024-08-29 08:33:26.340 homeassistant kernel: usb 1-1.5: SerialNumber: DE2429465
2024-08-29 08:33:26.343 homeassistant kernel: cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
2024-08-29 08:33:26.344 homeassistant kernel: veth49dd62f: renamed from eth0
2024-08-29 08:33:26.344 homeassistant kernel: hassio: port 7(vethee9d22f) entered disabled state
2024-08-29 08:33:26.344 homeassistant kernel: hassio: port 6(vethad52264) entered disabled state
AdGuard DNS logs
2024/08/29 10:12:16.181335 [info] dnsproxy: entering tcp listener loop on [::1]:53
2024/08/29 11:02:37.603949 [error] dnsproxy: 172.30.32.3:53: response received over udp: "exchanging with 172.30.32.3:53 over udp: read udp 172.30.32.1:40327->172.30.32.3:53: i/o timeout"
2024/08/29 11:02:37.610480 [error] dnsproxy: upstream 172.30.32.3:53 failed to exchange ;55.68.168.192.in-addr.arpa. IN PTR in 2.044809467s: exchanging with 172.30.32.3:53 over udp: read udp 172.30.32.1:40327->172.30.32.3:53: i/o timeout
2024/08/29 11:02:38.609123 [error] dnsproxy: 172.30.32.3:53: response received over udp: "exchanging with 172.30.32.3:53 over udp: read udp 172.30.32.1:56334->172.30.32.3:53: i/o timeout"
2024/08/29 11:02:38.609266 [error] dnsproxy: upstream 172.30.32.3:53 failed to exchange ;55.68.168.192.in-addr.arpa. IN PTR in 2.003501523s: exchanging with 172.30.32.3:53 over udp: read udp 172.30.32.1:56334->172.30.32.3:53: i/o timeout
[11:12:28] INFO: Service Adguard Home exited with code 256 (by signal 9)
[11:12:30] INFO: Starting AdGuard Home server...
2024/08/29 11:12:36.124353 [info] AdGuard Home, version v0.107.51
2024/08/29 11:32:40 [alert] 340#340: worker process 376 exited on signal 9
s6-supervise adguard: warning: finish script lifetime reached maximum value - sending it a SIGKILL
s6-supervise nginx: warning: finish script lifetime reached maximum value - sending it a SIGKILL
In Home Assistant → System → Hardware: my processor is averaging 15% and the memory is at 66% (0.6 / 1GB)
Did you ever figure anything out? I have the same hardware (RPi 3 with 1GB RAM and a quality SD card) and have a similar issue. Luckily for me this is just my secondary DNS server, so it doesn’t bother me, but I have other monitoring software that pings it every 5 mintues and it’s only up about 95% of the time. Some days it’s 100%, but others are closer to 90%. It seems intermittent.
When I look at the Adguard logs, I notice similar things to you especially these two lines that differ from the rest and seem to imply it is fully restarting:
2025/03/15 14:26:22.951785 [info] dnsproxy: entering listener loop proto=tcp addr=192.168.0.158:53
2025/03/15 14:26:22.956255 [info] dnsproxy: entering listener loop proto=tcp addr=127.0.0.1:53
2025/03/15 14:26:22.962603 [info] dnsproxy: entering listener loop proto=tcp addr=[fe80::c6ea:8486:ba19:b2a5%enu1u1]:53
2025/03/15 14:26:22.963848 [info] dnsproxy: entering listener loop proto=tcp addr=[::1]:53
[14:29:30] INFO: Service Adguard Home exited with code 256 (by signal 9)
[14:29:31] INFO: Starting AdGuard Home server...
2025/03/15 14:29:33.378475 [info] AdGuard Home, version v0.107.57
2025/03/15 14:29:33.406608 [info] tls: using default ciphers
Also the lines shortly before and after don’t seem that helpful to me even thought I enabled debug level logging. I personally think it is some sort of resource limitation on our RPis, but idk. I’ve had worse stability issues in the past when I ran more add-ons (Node Red, ESPHome, etc.), but I’ve offloaded those all to my other server now so I don’t run hardly anything except HAOS on the RPi and the overall system is more stable, but AdGuard is not.
I figured it was just not enough system resources for all of that to run with modern HA versions and all those add-ons installed.
I ended up getting a new mini-pc GMKtec G3 Plus with 16GB of RAM and 512GB of SSD and putting Proxmox on it and then HA as a VM. Works smooth and worth it!
