During the restart, HA start loading the UI but immediately after it crashes, and I don’t know why and how I can diagnose the root cause.
Supervisor seems running and “healthy”.
Can you help me??
What does the monitor output show?
standard prompt, nothing special.
Is it possible to access logs somehow?
can someone help me?
Try in the console to type “login” and hit enter, then type “journalctl” and hit enter.
You should now be in the logging system, so scroll forward to the current date for the crashes and see what you can find.
Hi.
I experience a similar problem. Did you find the root cause to why this happened?
Hello!
I have the same behavior as ghouse66. My HA tries to start up but fails. The log from journalctl -r is according to the picture below.
Do you have any clue to why the home assistant crashes with the exit code 256?
The exit 256 is not that important m
Signal 11 is though.
