Joe3
November 23, 2023, 9:13pm
1
Home assistant crashes twice a day.
Is there a log of why it crashes? I see the log for errors while it’s running.
Does anyone have experience with a particular integration that can Crash HA?
It would be nice to have a list of known integrations capable this.
Need more info, like what is the HA installed on, from your logs which integrations are you having issues with.
Depending on hardware, PS issue or a SSD issue could cause those symptoms.
any integration with a memory leak can/might cause this
WallyR
(Wally)
November 23, 2023, 9:25pm
4
There should be a home-assistant.log.1 in your config folder, which is the log from the previous run, but crashes that bring HA down usually means there is no logging going on either.
