Why does home assistant constantly crash out when making even basic changes? I just started attempting to use home assistant coming from node red. Which at this point seems much more stable.
The web interface crashes out, but the config file passes the error check.
mqtt:
broker: 10.1.14.131
port: 1883
client_id: home-assistant-1
username: sdfasdfasd
password: asdfasdfadfasdf
light:
- platform: mqtt_json
state_topic: “bruh/sensornode1”
command_topic: “bruh/sensornode1/set”
brightness: true
flash: true
rgb: true
optimistic: false
qos: 0
platform: mqtt
name: “SN1 Humidity”
unit_of_measurement: “%”
value_template: ‘{{ value_json.humidity | round(1) }}’
platform: mqtt
##This sensor is not calibrated to actual LUX. Rather, this a map of the input voltage ranging from 0 - 1023.
unit_of_measurement: “LUX”
value_template: ‘{{ value_json.ldr }}’
platform: mqtt
value_template: ‘{{ value_json.motion }}’
platform: mqtt
name: “SN1 Temperature”
unit_of_measurement: “°F”
value_template: ‘{{ value_json.temperature | round(1) }}’
platform: mqtt
name: “SN1 Real Feel”
value_template: ‘{{ value_json.heatIndex | round(1) }}’
group:
sensor_node_1_card:
name: Sensor Node 1
entities:
- sensor.sn1_temperature
- sensor.sn1_humidity
- sensor.sn1_ldr
- sensor.sn1_pir
- light.sn1_led
Someone’s gonna come along and tell you to properly format your code blocks… so I’ll do it …
properly format your code blocks… Its hard to evaluate anything without seeing what it really is.
I believe you need to specify every sensor separately.
Look into doing an !include sensors.yaml
https://github.com/bruhautomation/ESP-MQTT-JSON-Multisensor I take the video that goes along with this and the repo is outdated with a newer version of ha? He pastes it right in configuration.yaml in the video.
Making it a seperate file seems like a better idea like you say, do you see any problem with the config. I know for sure the mqtt feed is working because I have been using it node-red.
other than the sensor section it looks good, but I’d look at migrating it to a separate file.
Not sure if it matters, but I’m using a raspbery pi 2. It’s fresh install. Any issues with the latest version? Any commands to look at the crash log via ssh?
I created a folder called sensors, added an entry sensor: !include_dir_list sensors/ , and created a sensors/sensor1.yaml
I get zero errors, and nothing on the dashboard. I can add this in node-red in 2 minutes.
Any ideas?
If you’re in fact adding it you can go into dev tools to see if it’s actually created.
this is my garage door opener
- platform: mqtt
name: Garage Door Status
state_topic: "ha/garage_door_status"
retain: false
inside a yaml file,
my configuration.yaml says
sensor: !include_dir_merge_list includes/sensors/
Thanks! That worked. I did find I had to cut the power to the device a few times as it doesn’t restart properly.
I also found that there were two “sensor” sections. There’s one in there by default for weather.
