I’ve been running Home Assistant on a Raspberry Pi 4B with 2GB RAM for about 18 months. Its in an Argon ONE V2 case with an Argon ONE power supply. I am running Z-Wave via a Z-Wave.me USB stick, ZHA via a Popp ZB Shield, have a SSM-D (replacement D2 here SSM-D2)and am running it from a 240G Kingston USB SSD. I have the following integrations:
- AccuWeather
- Apple TV
- BMW Connected Drive
- Broadlink
- Fully Kiosk Browser
- Generic Camera
- Google Nest
- HACS
- VELUX Gateway as a HomeKit accessory
- HomeKit
- Logitech Harmony Hub
- Mosquitto
- Nest Protect
- NUT
- OpenUV
- SmartThings
- Sonos
- Sony Bravia TV
- Speedtest
- MariaDB
- Tasmota
- Thermal Comfort
- Z-Wave JS
- ZHA
And the following Add-ons:
- AppDaemon
- ArgonOne Active Cooling
- Duck DNS
- File Editor
- Grafana
- InfluxDB
- Lets Encrypt
- MariaDB
- Mosquito Broker
- NGINX
- php-nginx
- Portainer
- rest980 docker image
- Samba Share
- Studio code server
- Terminal and SSH
- WireGuard
- Z-Wave JS
Until 6 months ago, this all worked fine, and then I started to see periods where Home Assistant would hang and nothing would respond. The only way of solving this was to wait (sometimes up to 6 hours), or restart the Pi. The frequency of occurrences has increased over the last 6 months to the point where it will do it every day. It seems to happened most often at about 0500 BST and then when we put the clocks back last weekend, I noticed that it was at 0400 GMT, so is not changed by daylight savings. I’m mitigating it by running a script that restarts the Pi at 0400 every day but can’t find the cause. I have tried disabling all the Integrations at some point or another and it still happens. I suspect it may be hardware, but how do I find out? I’ve looked at the logs and can’t see what’s likely to be responsible.
Guyan
