Home-assistant.db deleted, but not re-created (Hassio)
Hi
Since my home-assistant.db was really large (almost 2GB) I decided to deleted (I have read some message about it), but now it has not been created again.
I have Maria DB and this is my config
recorder:
  purge_keep_days: 1
  purge_interval: 1
  db_url: mysql://hass:xxxxxx@core-mariadb/homeassistant
  exclude:
    entities:
      - camera.meteoeu
      - camera.meteoit
      - camera.patio
      - camera.porta
      - camera.vialetto
The Maria DB Log ends with
[INFO] Start MariaDB
181205 18:21:27 mysqld_safe Logging to '/data/databases/core-mariadb.err'.
181205 18:21:27 mysqld_safe Starting mysqld daemon with databases from /data/databases
[INFO] Init custom database
[INFO] Create database homeassistant
[INFO] Init/Update users
[INFO] Create user hass
[INFO] Init/Update rights
[INFO] Alter rights for hass@% - homeassistant
What can I do/check?
If you use Maria DB, there will be no home-assistant.db file to create.
Maria DB looks good. What is the problem?
@VDRainer thanks
I didn’t know about it.
My issue is that when I try to see the historical data, I get stuck in a white page, without showing the sensors and other stuff, and the browser hangs asking me if I want to wait or close the page.
Where I can see how big is the db using MariaDb?
Is there another Db to use to get better performance looking for historical data?
Same here. I switched to mariadb but same as using HA database. I think there is something in my setup flooding the logs. I’m not sure. I don’t know how to check mariadb to see whats up…
I will revert back to standard DB and then try to limit recorder and history like this
recorder:
  purge_keep_days: 7
  purge_interval: 1
  exclude:
    domains:
      - automation
      - weblink
      - updater
      - sensor
      - switch
      - media_player
      - light
    entities:
      - sun.sun
history:
  exclude:
    domains:
      - automation
      - weblink
      - updater
      - sensor
      - switch
      - media_player
      - light
and then I will look how it’s going
