I’m not quite sure when this started (within the past couple of days) but my Home Assistant Companion (2024.3) on MacOS no longer connects to HA. I can connect just fine from the same machine from the browser. Also I use Streamdeck with buttons that use the websocket HA interface and they are no longer working either. I am running:
Core 2024.4.0
Supervisor 2024.03.1
Operating System 12.1
Frontend 20240403.1
Any help getting these functions working again would be most appreciated.
I realized that the HA Companion app is actually the ios app that should run on MacOS but I deleted it and have downloaded the proper v 1.5.3 MacOS HA Desktop. This app won’t start at all. I tried running it from the CLI just to see what messages I’d get that might help:
./Home\ Assistant\ Desktop
14:00:31.419 ⺠homeassistant-desktop started
14:00:31.422 ⺠Platform: darwin arm64
14:00:31.447 ⺠Checking for update
objc[26827]: Class WebSwapCGLLayer is implemented in both /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libANGLE-shared.dylib (0x25d006270) and /Applications/Home Assistant Desktop.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Libraries/libGLESv2.dylib (0x10a8da978). One of the two will be used. Which one is undefined.
14:00:31.760 ⺠Update for version 1.5.3 is not available (latest version: 1.5.3, downgrade is disallowed).
14:00:31.764 ⺠Initialized main window
14:00:31.885 ⺠Initialized Tray menu
14:00:31.902 ⺠Initialized availability check
