Unfortunately, my home assistant dies after running for a while. I am running Hassbian on a Raspberry Pi 3+. I checked over SSH with systemctl systemstatus before leaving home today and got this output:
Feb 18 07:10:23 hassbian hass[1379]: File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/zwave/node_entity.py”, line 51, in maybe_schedule_update
Feb 18 07:10:23 hassbian hass[1379]: self.hass.add_job(self._schedule_update)
Feb 18 07:10:23 hassbian hass[1379]: File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/core.py”, line 246, in add_job
Feb 18 07:10:23 hassbian hass[1379]: self.loop.call_soon_threadsafe(self.async_add_job, target, *args)
Feb 18 07:10:23 hassbian hass[1379]: File “/usr/lib/python3.5/asyncio/base_events.py”, line 618, in call_soon_threadsafe
Feb 18 07:10:23 hassbian hass[1379]: self._check_closed()
Feb 18 07:10:23 hassbian hass[1379]: File “/usr/lib/python3.5/asyncio/base_events.py”, line 357, in _check_closed
Feb 18 07:10:23 hassbian hass[1379]: raise RuntimeError(‘Event loop is closed’)
Feb 18 07:10:23 hassbian hass[1379]: RuntimeError: Event loop is closed
I am not very good with Linux and all that. Anyone that can give me instructions on how I can figure out what’s wrong when I get home tonight?
Seems to be a Z-wave issue, but I have no idea why that would crash the frontend…
2019-02-20 15:14:07 ERROR (Dummy-27) [openzwave] Error in manager callback
File “/srv/homeassistant/lib/python3.5/site-packages/openzwave/network.py”, line 952, in zwcallback
self._handle_value_changed(args)
File “/srv/homeassistant/lib/python3.5/site-packages/openzwave/network.py”, line 1504, in _handle_value_changed
‘value’ : self.nodes[args[‘nodeId’]].values[args[‘valueId’][‘id’]]})
File “/srv/homeassistant/lib/python3.5/site-packages/pydispatch/dispatcher.py”, line 338, in send
**named
File “/srv/homeassistant/lib/python3.5/site-packages/pydispatch/robustapply.py”, line 55, in robustApply
return receiver(*arguments, **named)
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/zwave/node_entity.py”, line 138, in network_node_changed
self.node_changed()
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/zwave/node_entity.py”, line 179, in node_changed
self.maybe_schedule_update()
I noticed memory links or high cpu use in other app containers crashing HA a while back.after that I began limiting could and RAM for my containers to 1.5 or double Dev recommendations for all my containers
I’ve also had system updates affecting python affect HA or docker if I didn’t reboot shortly after
Hmm, that could be the thing yeah. I am running Hassbian, which is in a virtual environment. No clue how that works compared to docker. Could this still be the case?
