I needed to be able to access devices on the local network so I installed zerotier on a raspberry Pi4 and configured the bridge according to these instructions.
Everything worked fine, I had access to devices from outside the network, so I proceeded to install Home assistant in the docker. I installed docker, agent-os, etc. I installed home assistant, after installing it, I could no longer access my devices on the network. What could be the reason why bridges are disabled after installing home assistant
