Home Assistant release with the issue:
version - 0.90.2
Operating environment (Hass.io/Docker/Windows/etc.):
VirtualBox (macOS Mojave host) - hassos_ova-2.11.vdi.gz
VB Network - Bridge to en0 (wifi)
Component/platform:
components/xiaomi_aqara
Description of problem:
I have:
- Xiaomi Mijia Gateway lumi.gateway.v3
- Motion Sensor (1st generation)
- Temperature and Humidity Sensor (1st generation)
- Door and Window Sensor (1st generation)
I can toggle “Gateway Light”, and get information about temperature and humidity but motion sensor dont work.
Problem-relevant configuration.yaml
entries and (fill out even if it seems unimportant):
xiaomi_aqara: discovery_retry: 5 gateways: - key: KEY_FROM_MY_MI_HOME_APP
Logs
Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
11:59 components/device_tracker/__init__.py (ERROR)
Ended unfinished session (id=10 from 2019-03-31 08:31:33.423301)
11:59 components/recorder/__init__.py (WARNING)
I have updates:
- I try to open door and reload virtual machine.
- After loading,
Door sensor
was “opened” - I close door and
Door sensor
switched to “closed”
Then i try to open door again and Door senson
do not react on this.
(mihome app react on all events)
