Hi, I am currently running the latest home assistant Docker Container on my server but it is constantly crashing with the following error log:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 226, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 181, in main
args = get_arguments()
File "/usr/src/homeassistant/homeassistant/__main__.py", line 92, in get_arguments
default=config_util.get_default_config_dir(),
AttributeError: module 'homeassistant.config' has no attribute 'get_default_config_dir'
[14:07:14] INFO: Home Assistant Core finish process exit code 1
[14:07:14] INFO: Home Assistant Core service shutdown
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Does anyone know how to fix this this? Thank you in advance.
