It seems 50/50 weather my HA starts when I reboot my HassIO machine. If the container does not start I have to SSH in and start it manually. Here’s my info:
arch armv7l
dev false
docker true
hassio true
os_name Linux
python_version 3.7.3
timezone Europe/London
version 0.92.2
virtualenv false
Lovelace
mode auto-gen
Running on a RPi3, good SD card, external MariaDB 10, good PSU, etc. When the container does not start, the Web UI just does not load, so I have to SSH in:
hassio > login
# docker container exec homeassistant cat /config/home-assistant.log
Error response from daemon: Container 722622fe4465720b449f8717c80c52968eac8b6a36e83a9b55709ea576d8e3df is not running
# docker container list
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
6a0a082a993c homeassistant/armhf-hassio-supervisor "python3 -m hassio" 2 weeks ago Up 10 months hassos_supervisor
# docker container start homeassistant
homeassistant
722622fe4465 homeassistant/raspberrypi3-homeassistant "/bin/entry.sh pytho…" 5 days ago Up 3 seconds homeassistant
# date
Wed May 8 16:37:55 UTC 2019
# uptime
16:47:22 up 13 min, load average: 0.03, 0.17, 0.15
Here’s my log from the HassIO supervisor:
18-06-22 11:12:18 INFO (MainThread) [__main__] Initialize Hass.io setup
18-06-22 11:12:19 INFO (MainThread) [__main__] Setup HassIO
18-06-22 11:12:19 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 162
18-06-22 11:12:19 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
18-06-22 11:12:19 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
18-06-22 11:12:19 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
18-06-22 11:12:19 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
18-06-22 11:12:19 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
18-06-22 11:12:19 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: de.pengutronix.rauc - /
18-06-22 11:12:19 INFO (MainThread) [hassio.host.info] Update local host information
18-06-22 11:12:19 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
18-06-22 11:12:19 INFO (MainThread) [hassio.host.services] Update service information
18-06-22 11:12:19 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
18-06-22 11:12:19 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
18-06-22 11:12:19 INFO (MainThread) [hassio.host.services] Reload local service hassos-apparmor.service
18-06-22 11:12:19 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
18-06-22 11:12:19 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.92.2
18-06-22 11:12:20 INFO (MainThread) [hassio.hassos] Detect HassOS 2.11 on host system
18-06-22 11:12:20 INFO (SyncWorker_0) [hassio.docker.hassos_cli] Found HassOS CLI homeassistant/armhf-hassio-cli with version 9
18-06-22 11:12:20 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/core repository
18-06-22 11:12:20 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/git/a0d7b954 repository
18-06-22 11:12:21 INFO (MainThread) [hassio.addons] Load add-ons: 57 all - 57 new - 0 remove
18-06-22 11:12:21 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/armv7-addon-duckdns with version 1.6
18-06-22 11:12:21 INFO (SyncWorker_4) [hassio.docker.interface] Attach to homeassistant/armv7-addon-nginx_proxy with version 2.1
18-06-22 11:12:21 INFO (SyncWorker_5) [hassio.docker.interface] Attach to homeassistant/armhf-addon-git_pull with version 7.2
18-06-22 11:12:21 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
18-06-22 11:12:21 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://s3.amazonaws.com/hassio-version/stable.json: Cannot connect to host s3.amazonaws.com:443 ssl:True [SSLCertVerificationError: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1056)')]
18-06-22 11:12:21 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
18-06-22 11:12:21 INFO (MainThread) [hassio.discovery] Load 0 messages
18-06-22 11:12:21 INFO (MainThread) [hassio.ingress] Load 0 ingress session
18-06-22 11:12:21 INFO (MainThread) [__main__] Run Hass.io
18-06-22 11:12:21 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
18-06-22 11:12:21 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
18-06-22 11:12:21 INFO (MainThread) [hassio.addons] Startup initialize run 0 add-ons
18-06-22 11:12:21 INFO (MainThread) [hassio.core] Hass.io reboot detected
18-06-22 11:12:21 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
18-06-22 11:12:21 INFO (MainThread) [hassio.core] Hass.io is up and running
19-05-08 16:40:13 INFO (SyncWorker_19) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-duckdns with version 1.6
19-05-08 16:40:13 INFO (SyncWorker_4) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-nginx_proxy with version 2.1
Also my HassIO addons no longer auto-start, they have to be started manually.
Any idea on how I can fix this?
