Hello HA teams,
Once the Docker Engine is upgraded from 27.1.1 to 28.1.1, and the runc in docker engine is also upgraded from 1.1.13 to 1.2.6, and the latest home assistant docker container will fail to run in the same environment. The only different configuration is the Docker engine upgraded.
Does anyone can help on this?
Much appreciate !!
The error message is as the following:
docker start Home-Assistant
Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: chmod /dev/console: read-only file system: unknown
Error: failed to start containers: Home-Assistant
It’s really a problem.
HA container did not work anymore on asustor NAS using last docker engine provided by Asustor…
Same error message
Help needed
Thanks in advance
