I could use some advice, trying to have Home Assistant Container core-2021.12.10 running on an Asustor NAS connect to InfluxDb:2.0 Docker on same machine.
Being new to Docker, this might be a setup issue around the Docker Containers, but what I get is the error message below in the HA gui when restarting the HA docker.
2022-02-07 18:00:52 ERROR (influxdb) [homeassistant.components.influxdb] Cannot connect to InfluxDB due to ‘[Errno 2] No such file or directory’. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible.
Does anyone know exactly what that means, and what level of error this is?
Is the ‘[Errno 2] No such file or directory’ string coming from HA or from InfluxDb? If I type an invalid IP I get a different kind of message…
How can I debug this further?
The HA runs in “host” mode network sharing IP 192.168.0.100 with the NAS, influxdb in bridged mode IP 172.17.0.3 publishing port 49155 which is mapped to internal 8086.
I can browse the influxdb from a PC on the local network on http://192.168.0.100:49155
I’ve tried various variants for the setup in HA, but this is the current one:
influxdb:
api_version: 2
ssl: false
host: 192.168.0.100
port: 49155
verify_ssl: false
bucket: e11289f58c66aaa8
organization: [16 hexdigits from DB GUI ]
token: [TOKEN STRING GENERATED IN DB GUI]
tags:
source: HA
max_retries: 3
measurement_attr: entity_id
include:
domains:
- sensor
- binary_sensor
For host I’ve tried at least localhost, 127.0.0.1, 192.168.0.100, and 172.17.0.3 port 8086.
for bucket I’ve tried both the hexstring and the real name home_assistant.
I’ve used influxdb-client-ruby and been able to write data to the InfluxDb that appear in the WEB Gui of the database. This was ran towards 192.168.0.100:49155 from the NAS host.
From within the HA container (shell) I can do a wget http://localhost:49155/index.html and get a file that is obviously originating from the InfluxDb web server.
I’ve tried with InfluxDb:latest as well, same problem.
Any tips or suggestion to what to try would be appreciated a lot.
Rgds,
Sigurd.
