Hi all
I’m having some issues bringing up the docker version of Home Assistant on my Raspberry Pi (4B). I have copied the sample docker compose file from the documentation and changed the config location. The container loads up when I issue the command but I can’t seem to access it. Does anyone know why?
Docker Compose:
version: '3'
services:
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:stable"
volumes:
- ./config:/config
- /etc/localtime:/etc/localtime:ro
restart: unless-stopped
privileged: true
network_mode: host
The container comes up when I use docker-compose up
[email protected]:~/Containers/homeassistant $ docker-compose up
Starting homeassistant ... done
Attaching to homeassistant
homeassistant | [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
homeassistant | [s6-init] ensuring user provided files have correct perms...exited 0.
homeassistant | [fix-attrs.d] applying ownership & permissions fixes...
homeassistant | [fix-attrs.d] done.
homeassistant | [cont-init.d] executing container initialization scripts...
homeassistant | [cont-init.d] done.
homeassistant | [services.d] starting services
homeassistant | [services.d] done.
but when I try to visit the IP address of my pi in my web browser I get nothing. I can’t even curl it from the pi itself.
[email protected]:~/Containers/homeassistant $ docker-compose up -d
[email protected]:~/Containers/homeassistant $ docker-compose ps
Name Command State Ports
homeassistant /init Up
[email protected]:~/Containers/homeassistant $ curl localhost:8123
curl: (7) Failed to connect to localhost port 8123: Connection refused
However I can open a shell inside the container and curl it from there:
[email protected]:~/Containers/homeassistant $ docker-compose exec homeassistant sh
/config # curl localhost:8123 -v
* Trying 127.0.0.1:8123...
* Connected to localhost (127.0.0.1) port 8123 (#0)
> GET / HTTP/1.1
> Host: localhost:8123
> User-Agent: curl/7.78.0
> Accept: */*
* Mark bundle as not supporting multiuse
< HTTP/1.1 302 Found
< location: /onboarding.html
< Content-Length: 0
< Content-Type: application/octet-stream
< Date: Tue, 14 Dec 2021 18:15:43 GMT
< Server: Python/3.9 aiohttp/3.8.1
* Connection #0 to host localhost left intact
Just to make sure I’m using the right port I have also added a http section to my ./config/configuration.yaml
http:
server_port: 8123
Unsuprisingly that doesn’t seem to change anything and now I’m at a complete loss. The log file remains completely empty so I’ve run out of ideas. Any help would be appreciated!
