Hi everyone,
I decided to work on creating a server that held all my projects on one device and use docker for the services.
The current setup is 2 odroid hc1’s , one is openmediavault and the other is home assistant OS.
The new setup will be a rockpro64 NAS server with openmediavault as the natively installed service on armbian buster running docker with a service for radicale caldav server, home assistant and nginx as a reverse proxy.
Through a lot of trial and error I believe I have it working correctly however a more experienced eye cast over my configuration, from the fine home assistant community would be much appreciated, before I write a tutorial for others to benefit from my research.
this is the main part of my configuration.yaml file
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
http:
use_x_forwarded_for: true
trusted_proxies:
- 127.0.0.1
ip_ban_enabled: true
login_attempts_threshold: 5
device_tracker:
- platform: nmap_tracker
hosts:
- 192.168.1.179
- 192.168.1.130
consider_home: 120
exclude:
- 192.168.1.136
this is my docker compose file
version: '3.7'
services:
nginx:
depends_on:
- radicale
- homeassistant
image: nginx:latest
container_name: nginx_reverse_proxy
volumes:
- /etc/localtime:/etc/localtime:ro
- /srv/dev-disk-by-label-Files/home/nginx.conf:/etc/nginx/nginx.conf
- /srv/dev-disk-by-label-Files/home/nginx/error.log:/etc/nginx/error.log
- /srv/dev-disk-by-label-Files/home/nginx/access.log:/etc/nginx/access.log
- /etc/letsencrypt/:/etc/letsencrypt/
- /srv/dev-disk-by-label-Files/home/nginx:/etc/nginx
restart: unless-stopped
network_mode: host
radicale:
image: tomsquest/docker-radicale
container_name: radicale
ports:
- 127.0.0.1:5232:5232
init: true
read_only: true
security_opt:
- no-new-privileges:true
cap_drop:
- ALL
cap_add:
- SETUID
- SETGID
- CHOWN
- KILL
healthcheck:
test: curl -f http://127.0.0.1:5232 || exit 1
interval: 30s
retries: 3
volumes:
- /srv/dev-disk-by-label-Files/home/radicale/data:/data
- /srv/dev-disk-by-label-Files/home/radicale/config:/config:ro
- /srv/dev-disk-by-label-Files/home/radicale/users:/etc/radicale/users
homeassistant:
container_name: home-assistant
image: homeassistant/home-assistant:stable
volumes:
- /srv/dev-disk-by-label-Files/home/homeassistant:/config
environment:
- TZ=Europe/London
restart: always
network_mode: host
and this is my nginx.conf file
user www-data;
worker_rlimit_core 500M;
worker_processes 1;
events {
worker_connections 1024;
http {
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
error_log /etc/nginx/error.log warn;
ssl_dhparam /etc/nginx/cert/dhparams.pem;
ssl_prefer_server_ciphers on;
ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384;
ssl_protocols TLSv1.2 TLSv1.3;
add_header Strict-Transport-Security "max-age=31536000; includeSubdomains";
ssl_stapling on;
ssl_stapling_verify on;
ssl_certificate /etc/letsencrypt/live/myserver.duckdns.org/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/myserver.duckdns.org/privkey.pem;
ssl_trusted_certificate /etc/letsencrypt/live/myserver.duckdns.org/chain.pem;
server {
listen 80;
server_name myserver.duckdns.org;
return 301 https://$server_name$request_uri;
server {
listen 443 ssl http2;
location /radicale/ {
proxy_pass http://localhost:5232/;
proxy_set_header X-Script-Name /radicale;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_pass_header Authorization;
server {
listen 80;
server_name myhomeassistant.duckdns.org;
server {
location / {
proxy_pass http://localhost:8123;
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
location /api/websocket {
proxy_pass http://localhost:8123/api/websocket;
I’ve then set the external IP in the home assistant UI
can anyone see any obvious issues with my configuration ? is there anything I should add to nginx.conf to increase security or improve performance?
thanks in advance
