Home Assistant does not appear to close
I tried closing HASS, but the CMD window appears to hang with:
INFO:homeassistant.core:Bus:Handling <Event call_service[L]: service=restart, domain=homeassistant, service_call_id=2057287953040-42, service_data=>
INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=2057287953040-42>
INFO:homeassistant.components.http:"POST /api/services/homeassistant/restart HTTP/1.1" 200 -
INFO:homeassistant.core:Stopping
INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
INFO:homeassistant.components.recorder:Closing database
Is this normal, if not any ideas what might be up?
Dave
I’ve been having this problem a bunch, and it seems to happen after I’ve left hass running without a restart for a while. I’m running on a RaspberryPi, and I’m wondering if it’s due to how slow writing can be on a Pi. Right now I’m just leaving mine running to see how long it will go, and if it’s really stalled or just slow. We’re up to 20 minutes so far.
This have happened to me some times, but Ive never given it more than a minute until I cancel the operation.
I am seeing something similar - I am running hass as a service and sometimes a shutdown or restart hangs until I kill the process then it starts up again, usually with no issues., A couple of times I believe this may have corrupted my ZWave config for a device. forcing me to remove and re-add it.
After spending a bunch of time with HA on a dev box, I’m pretty sure my issues are just due to the fact that my pi is old and slow. It’s a Pi 1. The VM I’m using for dev has no such issues, even if I leave it running for days. I think I just need to spend the $35 on the Pi 3 and be done with it.
Interesting - I am running on a PI 3 and I am seeing issues … let me know if the 3 solves yours.
It’s been a year and it seems the bug is still there. I’m seeing this randomly on a Raspberry Pi 2 system with hassbian.
