Edit : stupid me, spend hours searching, until I saw I made a typing error.
I have installed Home assistant on a Pi, Mosquitto on another Pi.
this is the configuration.yaml :
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
mqtt:
broker: 10.0.0.63
port: 1883
discovery: true
discovery_prefix: homeassistent
username: xxxx
password: xxxx
group: !include groups.yaml
script: !include scripts.yaml
logger:
default: info
logs:
homeassistant.components.mqtt: debug
This is the system log :
19-07-01 16:36:54 INFO (MainThread) [__main__] Initialize Hass.io setup
19-07-01 16:36:54 INFO (MainThread) [__main__] Setup HassIO
19-07-01 16:36:54 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 167
19-07-01 16:36:54 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-07-01 16:36:54 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-07-01 16:36:54 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-07-01 16:36:55 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-07-01 16:36:55 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-07-01 16:36:56 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: de.pengutronix.rauc - /
19-07-01 16:36:56 INFO (MainThread) [hassio.host.info] Update local host information
19-07-01 16:36:56 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-07-01 16:36:56 INFO (MainThread) [hassio.host.services] Update service information
19-07-01 16:36:56 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-07-01 16:36:56 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
19-07-01 16:36:56 INFO (MainThread) [hassio.host.services] Reload local service hassos-apparmor.service
19-07-01 16:36:56 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
19-07-01 16:36:56 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/raspberrypi2-homeassistant with version 0.95.4
19-07-01 16:36:57 INFO (MainThread) [hassio.hassos] Detect HassOS 2.12 on host system
19-07-01 16:36:57 INFO (SyncWorker_3) [hassio.docker.hassos_cli] Found HassOS CLI homeassistant/armv7-hassio-cli with version 9
19-07-01 16:36:57 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-07-01 16:36:57 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-07-01 16:36:58 INFO (MainThread) [hassio.store] Load add-ons from store: 59 all - 59 new - 0 remove
19-07-01 16:36:58 INFO (MainThread) [hassio.addons] Found 4 installed add-ons
19-07-01 16:36:58 INFO (SyncWorker_4) [hassio.docker.interface] Attach to homeassistant/armv7-addon-configurator with version 3.4
19-07-01 16:36:58 INFO (SyncWorker_3) [hassio.docker.interface] Attach to homeassistant/armv7-addon-samba with version 8.1
19-07-01 16:36:58 INFO (SyncWorker_2) [hassio.docker.interface] Attach to homeassistant/armv7-addon-mosquitto with version 4.3
19-07-01 16:36:58 INFO (SyncWorker_8) [hassio.docker.interface] Attach to homeassistant/armv7-addon-ssh with version 6.0
19-07-01 16:36:58 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
19-07-01 16:37:01 INFO (MainThread) [hassio.snapshots] Found 1 snapshot files
19-07-01 16:37:01 INFO (MainThread) [hassio.discovery] Load 0 messages
19-07-01 16:37:01 INFO (MainThread) [hassio.ingress] Load 2 ingress session
19-07-01 16:37:01 INFO (MainThread) [__main__] Run Hass.io
19-07-01 16:37:01 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-07-01 16:37:01 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-07-01 16:37:01 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-07-01 16:37:01 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-ons
19-07-01 16:37:01 INFO (MainThread) [hassio.addons] Phase 'services' start 2 add-ons
19-07-01 16:37:08 INFO (SyncWorker_4) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-samba with version 8.1
19-07-01 16:37:11 INFO (SyncWorker_3) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-ssh with version 6.0
19-07-01 16:37:17 INFO (SyncWorker_11) [hassio.docker.interface] Start homeassistant/raspberrypi2-homeassistant
19-07-01 16:38:34 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-07-01 16:38:34 INFO (MainThread) [hassio.addons] Phase 'application' start 1 add-ons
19-07-01 16:38:43 INFO (SyncWorker_7) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-configurator with version 3.4
19-07-01 16:38:48 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-07-01 16:38:48 INFO (MainThread) [hassio.core] Hass.io is up and running
19-07-01 16:39:12 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
the contents of /config/home-assistant.log
2019-07-01 16:38:04 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds.
2019-07-01 16:38:04 INFO (MainThread) [homeassistant.setup] Setting up http
2019-07-01 16:38:04 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.1 seconds.
2019-07-01 16:38:04 INFO (MainThread) [homeassistant.setup] Setting up system_log
2019-07-01 16:38:04 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2019-07-01 16:38:04 INFO (MainThread) [homeassistant.setup] Setting up recorder
2019-07-01 16:38:07 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 2.9 seconds.
2019-07-01 16:38:07 INFO (MainThread) [homeassistant.setup] Setting up sun
2019-07-01 16:38:08 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.4 seconds.
2019-07-01 16:38:11 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2019-07-01 16:38:11 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds.
2019-07-01 16:38:11 INFO (MainThread) [homeassistant.setup] Setting up person
2019-07-01 16:38:11 INFO (MainThread) [homeassistant.setup] Setting up updater
2019-07-01 16:38:11 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
2019-07-01 16:38:11 INFO (MainThread) [homeassistant.setup] Setting up met
2019-07-01 16:38:11 INFO (MainThread) [homeassistant.setup] Setup of domain met took 0.0 seconds.
2019-07-01 16:38:11 INFO (MainThread) [homeassistant.setup] Setting up group
2019-07-01 16:38:11 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2019-07-01 16:38:11 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2019-07-01 16:38:11 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.1 seconds.
2019-07-01 16:38:12 INFO (SyncWorker_2) [homeassistant.loader] Loaded weather from homeassistant.components.weather
2019-07-01 16:38:12 INFO (MainThread) [homeassistant.setup] Setting up script
2019-07-01 16:38:12 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2019-07-01 16:38:12 INFO (SyncWorker_4) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2019-07-01 16:38:12 INFO (MainThread) [homeassistant.setup] Setting up config
2019-07-01 16:38:15 INFO (MainThread) [homeassistant.setup] Setting up api
2019-07-01 16:38:15 INFO (MainThread) [homeassistant.setup] Setting up history
2019-07-01 16:38:15 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2019-07-01 16:38:15 INFO (MainThread) [homeassistant.setup] Setting up webhook
2019-07-01 16:38:15 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2019-07-01 16:38:16 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2019-07-01 16:38:16 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
2019-07-01 16:38:16 INFO (MainThread) [homeassistant.setup] Setting up auth
2019-07-01 16:38:16 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2019-07-01 16:38:16 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2019-07-01 16:38:16 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2019-07-01 16:38:16 INFO (MainThread) [homeassistant.setup] Setting up system_health
2019-07-01 16:38:16 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
2019-07-01 16:38:16 INFO (MainThread) [homeassistant.setup] Setting up weather
2019-07-01 16:38:16 INFO (MainThread) [homeassistant.setup] Setup of domain weather took 0.0 seconds.
2019-07-01 16:38:16 INFO (MainThread) [homeassistant.setup] Setting up tts
2019-07-01 16:38:16 INFO (MainThread) [homeassistant.setup] Setup of domain api took 1.1 seconds.
2019-07-01 16:38:16 DEBUG (MainThread) [homeassistant.components.mqtt] Subscribing to homeassistent/#
2019-07-01 16:38:16 INFO (MainThread) [homeassistant.components.weather] Setting up weather.met
2019-07-01 16:38:16 INFO (MainThread) [homeassistant.setup] Setup of domain config took 4.7 seconds.
2019-07-01 16:38:18 INFO (MainThread) [homeassistant.setup] Setting up cloud
2019-07-01 16:38:22 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2019-07-01 16:38:22 INFO (MainThread) [homeassistant.setup] Setting up automation
2019-07-01 16:38:22 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2019-07-01 16:38:22 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2019-07-01 16:38:22 WARNING (MainThread) [homeassistant.setup] Setup of person is taking over 10 seconds.
2019-07-01 16:38:22 DEBUG (MainThread) [homeassistant.components.mqtt] Subscribing to homeassistent/#
2019-07-01 16:38:22 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2019-07-01 16:38:22 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.8 seconds.
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 4.7 seconds.
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 1.2 seconds.
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 6.5 seconds.
2019-07-01 16:38:23 INFO (SyncWorker_5) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.setup] Setting up frontend
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.1 seconds.
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.setup] Setting up notify
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds.
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.setup] Setting up map
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.setup] Setting up logbook
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.setup] Setting up panel_custom
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.setup] Setup of domain panel_custom took 0.0 seconds.
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2019-07-01 16:38:23 INFO (MainThread) [homeassistant.setup] Setup of domain person took 12.4 seconds.
2019-07-01 16:38:24 INFO (MainThread) [homeassistant.setup] Setting up hassio
2019-07-01 16:38:24 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 1.4 seconds.
2019-07-01 16:38:25 INFO (MainThread) [homeassistant.setup] Setting up default_config
2019-07-01 16:38:25 INFO (SyncWorker_17) [homeassistant.loader] Loaded stream from homeassistant.components.stream
2019-07-01 16:38:28 WARNING (MainThread) [homeassistant.components.weather] Setup of platform met is taking over 10 seconds.
2019-07-01 16:38:28 INFO (MainThread) [homeassistant.setup] Setting up stream
2019-07-01 16:38:28 INFO (MainThread) [homeassistant.setup] Setup of domain stream took 0.0 seconds.
2019-07-01 16:38:28 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 3.4 seconds.
2019-07-01 16:38:28 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 4.9 seconds.
2019-07-01 16:38:30 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 28.83s
2019-07-01 16:38:30 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2019-07-01 16:38:30 INFO (MainThread) [homeassistant.core] Timer:starting
2019-07-01 16:39:05 INFO (SyncWorker_2) [homeassistant.loader] Loaded gpslogger from homeassistant.components.gpslogger
2019-07-01 16:39:06 INFO (SyncWorker_0) [homeassistant.loader] Loaded heos from homeassistant.components.heos
2019-07-01 16:39:06 INFO (SyncWorker_19) [homeassistant.loader] Loaded dialogflow from homeassistant.components.dialogflow
2019-07-01 16:39:07 INFO (SyncWorker_6) [homeassistant.loader] Loaded wemo from homeassistant.components.wemo
2019-07-01 16:39:07 INFO (SyncWorker_8) [homeassistant.loader] Loaded hue from homeassistant.components.hue
2019-07-01 16:39:07 INFO (SyncWorker_16) [homeassistant.loader] Loaded tellduslive from homeassistant.components.tellduslive
2019-07-01 16:39:07 INFO (SyncWorker_4) [homeassistant.loader] Loaded zone from homeassistant.components.zone
2019-07-01 16:39:07 INFO (SyncWorker_7) [homeassistant.loader] Loaded smhi from homeassistant.components.smhi
2019-07-01 16:39:07 INFO (SyncWorker_17) [homeassistant.loader] Loaded hangouts from homeassistant.components.hangouts
2019-07-01 16:39:07 INFO (SyncWorker_11) [homeassistant.loader] Loaded point from homeassistant.components.point
2019-07-01 16:39:07 INFO (SyncWorker_18) [homeassistant.loader] Loaded zha from homeassistant.components.zha
2019-07-01 16:39:07 INFO (SyncWorker_9) [homeassistant.loader] Loaded openuv from homeassistant.components.openuv
2019-07-01 16:39:07 INFO (SyncWorker_3) [homeassistant.loader] Loaded owntracks from homeassistant.components.owntracks
2019-07-01 16:39:07 INFO (SyncWorker_15) [homeassistant.loader] Loaded esphome from homeassistant.components.esphome
2019-07-01 16:39:07 INFO (SyncWorker_1) [homeassistant.loader] Loaded homekit_controller from homeassistant.components.homekit_controller
2019-07-01 16:39:07 INFO (SyncWorker_14) [homeassistant.loader] Loaded zwave from homeassistant.components.zwave
2019-07-01 16:39:07 INFO (SyncWorker_5) [homeassistant.loader] Loaded daikin from homeassistant.components.daikin
2019-07-01 16:39:07 INFO (SyncWorker_13) [homeassistant.loader] Loaded upnp from homeassistant.components.upnp
2019-07-01 16:39:07 INFO (SyncWorker_10) [homeassistant.loader] Loaded ios from homeassistant.components.ios
2019-07-01 16:39:07 INFO (SyncWorker_19) [homeassistant.loader] Loaded simplisafe from homeassistant.components.simplisafe
2019-07-01 16:39:07 INFO (SyncWorker_12) [homeassistant.loader] Loaded lifx from homeassistant.components.lifx
2019-07-01 16:39:07 INFO (SyncWorker_2) [homeassistant.loader] Loaded iqvia from homeassistant.components.iqvia
2019-07-01 16:39:07 INFO (SyncWorker_6) [homeassistant.loader] Loaded emulated_roku from homeassistant.components.emulated_roku
2019-07-01 16:39:07 INFO (SyncWorker_8) [homeassistant.loader] Loaded locative from homeassistant.components.locative
2019-07-01 16:39:07 INFO (SyncWorker_16) [homeassistant.loader] Loaded axis from homeassistant.components.axis
2019-07-01 16:39:07 INFO (SyncWorker_4) [homeassistant.loader] Loaded ipma from homeassistant.components.ipma
2019-07-01 16:39:07 INFO (SyncWorker_0) [homeassistant.loader] Loaded geofency from homeassistant.components.geofency
2019-07-01 16:39:07 INFO (SyncWorker_7) [homeassistant.loader] Loaded luftdaten from homeassistant.components.luftdaten
2019-07-01 16:39:07 INFO (SyncWorker_17) [homeassistant.loader] Loaded rainmachine from homeassistant.components.rainmachine
2019-07-01 16:39:07 INFO (SyncWorker_11) [homeassistant.loader] Loaded toon from homeassistant.components.toon
2019-07-01 16:39:07 INFO (SyncWorker_18) [homeassistant.loader] Loaded deconz from homeassistant.components.deconz
2019-07-01 16:39:07 INFO (SyncWorker_9) [homeassistant.loader] Loaded ifttt from homeassistant.components.ifttt
2019-07-01 16:39:07 INFO (SyncWorker_3) [homeassistant.loader] Loaded logi_circle from homeassistant.components.logi_circle
2019-07-01 16:39:07 INFO (SyncWorker_15) [homeassistant.loader] Loaded mailgun from homeassistant.components.mailgun
2019-07-01 16:39:08 INFO (SyncWorker_1) [homeassistant.loader] Loaded twilio from homeassistant.components.twilio
2019-07-01 16:39:08 INFO (SyncWorker_14) [homeassistant.loader] Loaded smartthings from homeassistant.components.smartthings
2019-07-01 16:39:08 INFO (SyncWorker_5) [homeassistant.loader] Loaded plaato from homeassistant.components.plaato
2019-07-01 16:39:08 INFO (SyncWorker_13) [homeassistant.loader] Loaded nest from homeassistant.components.nest
2019-07-01 16:39:08 INFO (SyncWorker_10) [homeassistant.loader] Loaded unifi from homeassistant.components.unifi
2019-07-01 16:39:08 INFO (SyncWorker_19) [homeassistant.loader] Loaded tradfri from homeassistant.components.tradfri
2019-07-01 16:39:08 INFO (SyncWorker_12) [homeassistant.loader] Loaded tplink from homeassistant.components.tplink
2019-07-01 16:39:08 INFO (SyncWorker_2) [homeassistant.loader] Loaded cast from homeassistant.components.cast
2019-07-01 16:39:08 INFO (SyncWorker_6) [homeassistant.loader] Loaded ambient_station from homeassistant.components.ambient_station
2019-07-01 16:39:08 INFO (SyncWorker_8) [homeassistant.loader] Loaded sonos from homeassistant.components.sonos
2019-07-01 16:39:08 INFO (SyncWorker_16) [homeassistant.loader] Loaded life360 from homeassistant.components.life360
2019-07-01 16:39:08 INFO (SyncWorker_4) [homeassistant.loader] Loaded adguard from homeassistant.components.adguard
2019-07-01 16:39:08 INFO (SyncWorker_0) [homeassistant.loader] Loaded somfy from homeassistant.components.somfy
2019-07-01 16:39:08 INFO (SyncWorker_7) [homeassistant.loader] Loaded homematicip_cloud from homeassistant.components.homematicip_cloud
2019-07-01 16:39:08 INFO (SyncWorker_17) [homeassistant.loader] Loaded ps4 from homeassistant.components.ps4
2019-07-01 16:39:08 INFO (SyncWorker_11) [homeassistant.loader] Loaded ambiclimate from homeassistant.components.ambiclimate
I see the device sending out homeassistant config messages :
nowhere in the files I see home assistent trying to connect to MQTT or an error message ? And the device is not found.
