Home assistant does not start after reboot
I had m HassIO running for over 4 months and just installed to the laster version. After a hard reboot my system is not coming online any more. I can access via SSH. I searched for days to find the issue, but I do not have enough experience to solve by myself, so hope someone can give me some directions. I have checked the configuration file and there are no errors in that. Let me know if I need to provide more information.
hassio su info
gives:
core-ssh:~# hassio su info
addons:
- description: Allows connections over SSH
  icon: false
  installed: "6.4"
  logo: true
  repository: core
  slug: core_ssh
  state: started
  version: "6.4"
- description: Upload your Hass.io backups to Dropbox
  icon: false
  installed: 1.3.0
  logo: false
  repository: 7be23ff5
  slug: 7be23ff5_dropbox_sync
  state: started
  version: 1.3.0
- description: Explore your SQLite database
  icon: true
  installed: 1.0.0
  logo: true
  repository: a0d7b954
  slug: a0d7b954_sqlite-web
  state: started
  version: 2.0.0
- description: An Open Source MQTT broker
  icon: false
  installed: "5.1"
  logo: true
  repository: core
  slug: core_mosquitto
  state: started
  version: "5.1"
- description: A cross-platform system monitoring tool
  icon: true
  installed: 0.5.5
  logo: true
  slug: a0d7b954_glances
  state: started
  version: 0.5.5
- description: Backup hass.io snapshots to Google Drive.
  icon: false
  installed: 1.5.0
  logo: false
  name: Backup Hassio to Google Drive
  repository: 3833edd4
  slug: 3833edd4_googlebackup
  state: started
  version: 1.5.0
- description: Centrally manage all your Sonoff-Tasmota devices
  icon: true
  installed: 0.8.2
  logo: true
  slug: a0d7b954_sonweb
  state: started
  version: 0.8.2
- description: Browser-based configuration file editor for Home Assistant
  icon: false
  installed: "3.5"
  logo: false
  repository: core
  slug: core_configurator
  state: started
  version: "3.5"
- description: Python Apps and HADashboard using AppDaemon 3.x for Home Assistant
  icon: true
  installed: 4.1.0
  logo: true
  slug: a0d7b954_appdaemon3
  state: started
  version: 4.1.0
- description: Free Dynamic DNS (DynDNS or DDNS) service with Let's Encrypt support
  icon: false
  installed: "1.9"
  logo: true
  repository: core
  slug: core_duckdns
  state: started
  version: "1.10"
- description: Simple, elegant and feature-rich CCTV/NVR for your cameras
  icon: true
  installed: 0.5.5
  logo: true
  slug: a0d7b954_motioneye
  state: stopped
  version: 0.5.5
- description: Zigbee to MQTT Bridge
  icon: false
  installed: 1.6.0
  logo: false
  repository: 7ad98f9c
  slug: 7ad98f9c_zigbee2mqtt
  state: started
  version: 1.6.0
- description: ESPHome Hass.io add-on for intelligently managing all your ESP8266/ESP32
    devices.
  icon: true
  installed: 1.13.6
  logo: true
  repository: 15ef4d2f
  slug: 15ef4d2f_esphome
  state: started
  version: 1.13.6
- description: Flow-based programming for the Internet of Things
  icon: true
  installed: 4.2.1
  logo: true
  slug: a0d7b954_nodered
  state: started
  version: 4.2.1
addons_repositories:
- https://github.com/hassio-addons/repository
- https://github.com/danielwelch/hassio-zigbee2mqtt
- https://github.com/esphome/hassio
arch: armv7
channel: stable
ip_address: 172.30.32.2
last_version: "189"
logging: info
timezone: Europe/Amsterdam
version: "189"
wait_boot: 5
the output of my log file:
2019-10-07 23:11:36 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for custom_updater which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-10-07 23:11:43 INFO (MainThread) [homeassistant.components.rflink] Initiating Rflink connection
2019-10-07 23:11:43 DEBUG (MainThread) [rflink.protocol] ignoring: ['digitech_*', 'rftech_*', 'firstline_*', 'sensor.alectov3_3000_*']
2019-10-07 23:11:43 INFO (MainThread) [homeassistant.components.rflink] Connected to Rflink
2019-10-07 23:11:44 DEBUG (MainThread) [rflink.protocol] connected
2019-10-07 23:11:51 DEBUG (MainThread) [rflink.protocol] received data: 20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
2019-10-07 23:11:51 DEBUG (MainThread) [rflink.protocol] got packet: 20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
2019-10-07 23:11:51 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'unknown', 'hardware': 'Nodo RadioFrequencyLink', 'firmware': 'RFLink Gateway', 'version': '1.1', 'revision': '48'}
2019-10-07 23:11:51 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'rflink', 'hardware': 'Nodo RadioFrequencyLink', 'firmware': 'RFLink Gateway', 'version': '1.1', 'revision': '48'}
2019-10-07 23:11:51 DEBUG (MainThread) [homeassistant.components.rflink] event of type unknown: {'id': 'rflink', 'hardware': 'Nodo RadioFrequencyLink', 'firmware': 'RFLink Gateway', 'version': '1.1', 'revision': '48'}
2019-10-07 23:11:51 DEBUG (MainThread) [homeassistant.components.rflink] unhandled event of type: unknown
2019-10-07 23:12:04 ERROR (MainThread) [homeassistant.setup] Setup failed for mqtt: Integration failed to initialize.
2019-10-07 23:12:04 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform mqtt.sensor: Unable to set up component.
2019-10-07 23:12:05 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback SerialTransport._read_ready()
  File "/usr/local/lib/python3.7/asyncio/events.py", line 88, in _run
    self._context.run(self._callback, *self._args)
  File "/usr/local/lib/python3.7/site-packages/serial_asyncio/__init__.py", line 106, in _read_ready
    self._protocol.data_received(data)
  File "/usr/local/lib/python3.7/site-packages/dsmr_parser/clients/protocol.py", line 83, in data_received
    data = data.decode('ascii')
UnicodeDecodeError: 'ascii' codec can't decode byte 0xfd in position 0: ordinal not in range(128)
Sounds like a HassIO issue, I’d move this thread to the hassIO section :slight_smile:
I ended up reinstalling hassio, it now works fine again.
