Hi!
I switched from openHAB to Home Assistant yesterday. I since like the way HA is built on python instead of java and just works… until now. I did some changes to my configuration.yaml, restarted HASS and now it just does not start correctly:
This is what the service looks like:
user@rain:~/.homeassistant$ service home-assistant@user status ◠[email protected] - Home Assistant Loaded: loaded (/etc/systemd/system/[email protected]; enabled; vendor preset: enabled) Active: active (running) since Wed 2017-02-08 11:47:53 CET; 13s ago Main PID: 2727 (hass) Tasks: 4 (limit: 4915) CGroup: /system.slice/system-home\x2dassistant.slice/[email protected] └─2727 /usr/bin/python3 /home/user/.local/bin/hass Feb 08 11:47:53 rain systemd[1]: Started Home Assistant. Feb 08 11:47:53 rain hass[2727]: Config directory: /home/user/.homeassistant
It just stops ath the “Config directory” line - no further information in the log as well:
I since reversed the changes I made to conifiguration.yaml, but the problem persists…
I renamed the .homeassistant directory and HA started up fine. Reversed that and it was back to being stuck. I edit the config files on a Windows machine using Notepad++ via a Samba Share…
Thanks for any help!
