Hi there,
Can somebody help me? I just updated through Lovelace to latest version, but now I find this in my log:
2020-12-17 20:10:42 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for satellitetracker which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-12-17 20:10:42 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for kia_uvo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-12-17 20:10:43 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-12-17 20:10:53 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2020-12-17 20:11:43 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: recorder
2020-12-17 20:12:43 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: recorder
2020-12-17 20:13:43 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: recorder
2020-12-17 20:14:43 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: recorder
2020-12-17 20:15:43 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: recorder
And I can’t connect to Home Assistant anymore - can somebody help me? Thank you in advance
