Hello everyone. I currently have some devices that measure voltage, current and electrical consumption. I recently added other gas and water consumption sensors. All of them are perfectly integrated with Home Assistant. I can measure instantaneous values and generate graphs without problems…
However, I have not been able to make these sensors visible on the Home Assistant energy panel in any way. The sensors simply do not appear in the list! I have tried to look at the documentation but have not been able to find anything so far, so I decided to consult the community to see if anyone can help me.
Sounds like you only have power sensors. The energy dashboard does not work with power sensors, it needs energy sensors.
Fortunately it is fairly easy to convert power to energy.
Feed your power sensors to Integral Helpers.
Make sure you read the section about choosing the correct method. If you are not sure which method to use post a history graph of your power sensor here and we can help you choose. Getting this right is important, it minimises approximation errors.
Once you have your energy sensors you can add them to the energy dashboard.
It’s really odd you dont already have those kWh sensors though, and we cant see properly because the resolution is a bit low.
Are you sure you just didnt enable them yet? there might be something under the
