I’m building a subflow to control lights. I’m trying to use a “Home Assistant Entities” switch node.
I was able to make it work in a flow with no issues, but my problem is that when I put it into a subflow and create copies of that subflow, the switch remains the same for all copies and does not create a new switch for each copy. If I toggle the switch from Home Assistant, all the subflows toggle.
How can I make the entities unique for each flow?
I have tried searching for documentation about the Node Red Companion Integration but couldn’t find anything.
