I’ve got an error at Home Assistant start:
Logger: homeassistant.components.esphome.dashboard
Source: helpers/update_coordinator.py:215
Integration: ESPHome (documentation, issues)
First occurred: 21:03:42 (1 occurrences)
Last logged: 21:03:42
Error requesting ESPHome Dashboard data: Cannot connect to host 127.0.0.1:63188 ssl:default [Connect call failed ('127.0.0.1', 63188)]
What does it mean?
poleax01
(Poleax01)
3
Check your firewall, i fix using:
sudo ufw allow 63188
JDv1
(Jd)
4
Hi. I have the same problem. Which firewall you mean? My router? Where to I run the sudo command?
poleax01
(Poleax01)
6
In my case at server, Ubuntu terminal.
