Home assistant error returned from supervisor system is not ready with state setup
I have just start to get this issue, that when reboot my Home Assistant it errors out with the following error message
“home assistant error returned from supervisor system is not ready with state setup”
I have google and I see that there is a work around, by running the command supervisor repair and then supervisor restart, and this get’s the HA up and running
if anyone knows how to resolve this issue, then I would very gratefully.
here is a copy of my log file for supervisor. my HA is running within a virtual Machine on a unraid server
22-08-23 18:47:14 INFO (MainThread) [supervisor.supervisor] Repairing Supervisor 2022.08.3
22-08-23 18:47:15 INFO (MainThread) [supervisor.core] Finished repair of Supervisor Environment
22-08-23 18:47:43 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
22-08-23 18:47:43 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
22-08-23 18:47:48 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
22-08-23 18:47:49 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
22-08-23 18:47:49 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
22-08-23 18:47:49 INFO (MainThread) [supervisor.core] Supervisor is down - 100
22-08-23 18:47:49 INFO (MainThread) [main] Closing Supervisor
[17:47:49] INFO: Supervisor restart after closing
22-08-23 17:47:49 INFO (MainThread) [main] Initializing Supervisor setup
22-08-23 17:47:49 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-08-23 18:47:49 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
22-08-23 18:47:49 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2022.08.3
22-08-23 18:47:49 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-08-23 18:47:50 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-08-23 18:47:50 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-08-23 18:47:50 INFO (MainThread) [main] Setting up Supervisor
22-08-23 18:47:50 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-08-23 18:47:50 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-08-23 18:47:50 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-08-23 18:47:50 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-08-23 18:47:50 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-08-23 18:47:50 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-08-23 18:47:50 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-08-23 18:47:50 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-08-23 18:47:50 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-08-23 18:47:50 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.resolve1
22-08-23 18:47:50 INFO (MainThread) [supervisor.host.info] Updating local host information
22-08-23 18:47:50 INFO (MainThread) [supervisor.host.services] Updating service information
22-08-23 18:47:50 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-08-23 18:47:50 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-08-23 18:47:50 INFO (MainThread) [supervisor.host.network] Updating local network information
22-08-23 18:47:51 INFO (MainThread) [supervisor.host.network] Updating local network information
22-08-23 18:47:51 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}
22-08-23 18:47:51 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
22-08-23 18:47:51 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to Package amd64-hassio-cli · GitHub with version 2022.06.0
22-08-23 18:47:51 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to Package amd64-hassio-dns · GitHub with version 2022.04.1
22-08-23 18:47:51 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-08-23 18:47:51 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to Package amd64-hassio-audio · GitHub with version 2022.07.0
22-08-23 18:47:51 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to Package amd64-hassio-observer · GitHub with version 2021.10.0
22-08-23 18:47:51 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to Package amd64-hassio-multicast · GitHub with version 2022.02.0
22-08-23 18:47:51 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-08-23 18:47:52 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to Package qemux86-64-homeassistant · GitHub with version 2022.8.6
22-08-23 18:47:52 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 3 Home Assistant secrets
22-08-23 18:47:52 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 8.5 / BootSlot B
22-08-23 18:47:52 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-08-23 18:47:52 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
22-08-23 18:47:52 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-08-23 18:47:53 INFO (MainThread) [supervisor.store] Loading add-ons from store: 66 all - 66 new - 0 remove
22-08-23 18:47:53 INFO (MainThread) [supervisor.addons] Found 9 installed add-ons
22-08-23 18:47:53 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-samba with version 10.0.0
22-08-23 18:47:53 INFO (SyncWorker_4) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-ssh with version 9.6.0
22-08-23 18:47:53 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to Package vscode/amd64 · GitHub with version 5.3.0
22-08-23 18:47:53 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-mosquitto with version 6.1.2
22-08-23 18:47:53 INFO (SyncWorker_6) [supervisor.docker.interface] Attaching to Package phpmyadmin/amd64 · GitHub with version 0.8.1
22-08-23 18:47:53 INFO (SyncWorker_7) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-mariadb with version 2.5.1
22-08-23 18:47:53 INFO (SyncWorker_5) [supervisor.docker.interface] Attaching to Package node-red/amd64 · GitHub with version 13.1.0
22-08-23 18:47:53 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-nginx_proxy with version 3.1.5
22-08-23 18:47:53 INFO (SyncWorker_3) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-configurator with version 5.3.3
22-08-23 18:47:53 INFO (MainThread) [supervisor.backups.manager] Found 23 backup files
22-08-23 18:47:53 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-08-23 18:47:53 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-08-23 18:47:53 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-08-23 18:47:53 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-08-23 18:47:53 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-08-23 18:47:53 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-08-23 18:47:53 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not running - CoreState.SETUP
22-08-23 18:47:53 INFO (MainThread) [main] Running Supervisor
22-08-23 18:47:53 INFO (MainThread) [supervisor.os.manager] Rauc: B - marked slot kernel.1 as good
22-08-23 18:47:53 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.INITIALIZE’ starting 0 add-ons
22-08-23 18:47:53 INFO (MainThread) [supervisor.core] Supervisor reboot detected
22-08-23 18:47:53 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-08-23 18:47:53 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-08-23 18:47:53 INFO (MainThread) [supervisor.host.info] Updating local host information
22-08-23 18:47:53 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-08-23 18:47:53 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-08-23 18:47:53 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-08-23 18:47:53 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-08-23 18:47:53 INFO (MainThread) [supervisor.host.services] Updating service information
22-08-23 18:47:53 INFO (MainThread) [supervisor.host.network] Updating local network information
22-08-23 18:47:53 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-08-23 18:47:53 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
22-08-23 18:47:53 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
22-08-23 18:47:53 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
22-08-23 18:47:53 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-08-23 18:47:53 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-08-23 18:47:53 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-08-23 18:47:54 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-08-23 18:47:54 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-08-23 18:47:55 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-08-23 18:47:55 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-08-23 18:47:55 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-08-23 18:49:51 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-08-23 18:49:51 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-08-23 18:50:15 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-08-23 18:50:16 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
