Just looking for some help before doing a fresh install, The other night everything was working the next day I couldn’t get into my home assistant so I restated it and after sometime still nothing so I thought I’d plug a monitor into the HDMI and in the screen shot is what I get in a endless loop, I have no idea what any of it means, is there any fixing it?
this is on a raspberry pi?
You cut of the last line in your image, often the last line is the mist important.
Edit, ah I see its looping.
Edit: If this is all you get from your PI, you could try to ssh into it if you know how to do this. If not, it might be easiest to just reflash the pi. You got a backup of your config?
